Results 1 to 10 of 19
Thread: Snorkels
    Mar 2011
    Snorkels
    I have been advised to fit a snorkel to my 4.2 deisel when crossing the simpson
    Any one can tell me what type I should get or are they really nescerary?
    Reg
  2. The Following User Says Thank You to kemsafe@bigpond.com For This Useful Post:
    Cuppa (14th April 2011)
    Banned Bigrig's Avatar
    Oct 2010
    South of Brissy, QLD
    What type wouldn't be so much the concern mate - that comes down to budget and looks - they all (reputable brands) do essentially the same thing so a no brainer on that one. Where you'll get conjecture is the topic of "are they really necessary". Probably a better question (because no, they aren't "necessary") is "what is the benefits of fitting one". That's probably going to be more unanimous across the answers. The benefits of fitting one are better air flow, the air intake sits higher and there is better ability for the snorkel to allow the engine to breath fresher cooler air that is being forcibly rammed down the air intake (so it's said - but having been out there, the dust is just as thick at 6 feet above the road as it is at 3 feet above the road, so that argument is a bit subjective!!). I found I got better fuel economy also (only slight) with the snorkel, and the obvious winner is being able to traverse deeper water without the fear of hydro locking your engine (will need diffs, transfer case and gearbox breathers all round for this also).
    I don't know that it is absolutely necessary to have one for the simpson trip and that should raise a few examples from people also, but it is not a bad addition to the vehicle in general mate for a range of reasons, and even just to give you peace of mind for the trip also!
    Good luck with the decision and no doubt others will throw up their two cents worth shortly ....
    Feb 2011
    Shed
    45 Post(s)
    As big rig stated the benefits are there, if your travelling in a "convoy" even two up stay back from the vehicle infront to clear the air of thick heavy bulldust give your snorkel a chance to do its job
    Patrol Guru rkinsey's Avatar
    Sep 2010
    Minchinbury
    I think you have covered all arguments. For me, I would install one just as a matter of course. You never know what you are going to come accross with a trip like this so following the boy scout code of "Be Prepared" is probably a good idea.
    I believe in travelling light but I also balance that with equipment you may need out in the wild. Also, what hapens if you come accross someone out there that needs your help and you dont have simple tools......
    Cheers,
    Rob
    Just about to jump into my next Patrol. A 2001 GU II TB45E .
    WARNING!: Do not ever use a towball as a recovery point. They are not rated and can become a deadly projectile during a recovery if they snap off, and they have done so with tragic results in the past.
    Expert HippoNZ's Avatar
    Feb 2011
    New Zealand
    Snorkels are great in general to have regardless of where your journey takes you. They a better for your engine in the long run. If your crossing dusty roads then some snorkels have filters in them also, helps catch bits and pieces before it reaches your main filter. I've heard also you can get better fuel economy from a snorkel. I don't know what the simpson is like so couldn't advise on that one but some one will be able to tell.
    Legendary timbar's Avatar
    Feb 2011
    perth
    Quote Originally Posted by Bigrig View Post
    Well Said Big Rig maybe AB could Help out with this one check out this thread
    http://www.nissanpatrol.com.au/forum...ll=1#post60275
    1989 GQ LPG / PET TB42 LWB WAGON 4'LIFT 33's
    WELCOME TO THE MUD PITT WE DRIVE NISSAN PATROLS
    SUCH IS LIFE Maxhead's Avatar
    ACT
    G'Day and welcome mate
    ________________________
    ______ 2017 D-Max _______
    Jul 2010
    Waterford West Qld
    One thing no one has offerewd is, you can turn head of snorkel to face rear, to stop dust being driven into snorkel, and air intake will pull in what air it needs.
    Tim
  10. #9
    Banned
    To all new members & those member who have joined in the last 4 months I'd like to introduce myself
    Hi all my name is Paul (patch697) & I am the Super Moderator here on the forum. I have been away for a spell & there will be a lot of new members who haven't met me yet so I'd like to extend a worm welcome from myself to you all & if you have any question or need any help don't hesitate to ask.
    I hope you all enjoy the forum.
    Paul
  11. #10
    Advanced chrissey's Avatar
    Apr 2011
    Mooloolaba
    Hi all,
    just reading this thread as I am about to get a snorkel fitted to my Safari. Now I read you would need "diffs, transfer case and gearbox breathers" fitted as well, what does that mean? Is a snorkel nonsense without having those things fitted as well and doing e.g a water crossing? Obviously you wont drown your engine if your diffs, or gearbox fails but still it will prevent you from carrying on travelling and cause cost intensive repairs, right?
