Results 1 to 10 of 12
Thread: Starter circuit problems
    Mar 2026
    I have a 2005 GQ td42 DX ute. Owned it since new 175000kms . Stock as a rock.
    Having intermittent no CRANKING problems. shorting out between the starter solenoid and starter positive works fine. Seems only to be when the engine is hot. I am looking for the location of the Fabled STARTER RELAY location. If anyone knows would be greatly appreciated.
    Kirren
    According to Patrol a Part its next the the main battery.
    https://patrolapart.com.au/product/g...er-motor-relay
    Check your earth points as well, can be fickle with temp if they are loose or degraded.
    Mar 2026
    Cheers Mate.
    Well found. $261 for a simple relay OMG. A Spot light relay will do fine i reckon. Once i find the F***er.
    Am looking near the battery and nothing looks like it yet.
    Thanks again
    Kirren.
  5. #5
    Mar 2026
    thanks will do.
    but still cant locate the relay.
  6. The Following User Says Thank You to Kizza23 For This Useful Post:
    PeeBee (30th March 2026)
    Mar 2026
    Quote Originally Posted by Kizza23 View Post
    Cheers Mate.
    Thanks again
    Kirren.
    ok not so simple, more of a small contactor .
  8. The Following User Says Thank You to Kizza23 For This Useful Post:
    Mar 2026
    OK here is the latest.
    The helpfull man at patrolapart says that the 2005 GU TD42ti does NOT have a starter relay fitted. The circuit is ignition barrel, straight to the starter solenoid.
  10. The Following User Says Thank You to Kizza23 For This Useful Post:
  11. #8
    Mar 2026
    sorry all.
    2005 GU TD42ti
  12. #9
    Check the earths. Even add another from the motor to the body then to the battery. GU's are notorious for earthing issues.
  13. The Following 3 Users Say Thank You to mudski For This Useful Post:
    Kizza23 (31st March 2026), NomadTech (30th March 2026), PeeBee (30th March 2026)
  14. #10
    Jan 2026
    Looking at the drawings now. Yep, on manuals the solenoid is powered directly from the ignition. As Mudski says: Check Earth resistance from starter body to battery negative. ...Or your starter solenoid is shot. Failing solenoids often manifest problems when they're hot.
    (I have the exact same vehicle, a 2005 TD42ti DX ute. Went and grabbed my good meter from the shed, measured the resistance from the body of my starter to the battery negative and it's too low for the meter to even read, just comes up 0.00 Ohms, if that helps as a reference).
  15. The Following User Says Thank You to NomadTech For This Useful Post:
