Page 59 of 188 FirstFirst ... 5758596061 ... LastLast
Results 581 to 590 of 1871
Thread: The "Tank" - Big, Grey and Ugly ..
  1. #581
    Simpson Desert GUtsy ute's Avatar
    Apr 2011
    Forestdale Brisbane
    Quote Originally Posted by Bigrig View Post
    Hey Gav
    Going to cut the cow catchers off tomorrow ... just them though, the rest is a joint effort! And by 'joint effort' I mean you!!! LOL ... just thought there is no reason they can't go whilst I'm in the cutting mode!!
    Nothing like the power of an angle grinder in the fist!!!
    Give it heaps, and we'll pretty it up on modification day!!
  2. The Following User Says Thank You to GUtsy ute For This Useful Post:
    Bigrig (19th May 2011)
  3. #582
    Legendary big_fletch's Avatar
    Oct 2010
    Tatura VIC
    That's it mate - no more damage ... I had to replace the flat 7 pin connector as a couple of wires had pulled from it, and when they opened it, it was pretty corroded anyway ...
    Yep 4wd's and plugs on the outside of a vehicle do not mix, replace a shipload at work..
    Love the plastic split tube and brackets, should be an Auto-elec mate LMFAO
    Qualified Auto-Electrician
    Apprentice Sparky
    Dont own a Patrol or any 4WD at the moment, hopefully will change into the future
  4. #583
    Good idea mate, Ive only had bluey a short while and already ive jammed the 7 pin in muddy clay...lol
  5. #584
    Patrol Freak Dark 1's Avatar
    Sep 2010
    Mundaring, Perth
    Looking good buddy, rear draws are one of those must have mods in my mind. Of course you know we MUST have photos.
    Watch out there's a Poo "Yota" lurking in the shadows !
  6. #585
    Banned Bigrig's Avatar
    Oct 2010
    South of Brissy, QLD
    Started the barwork today - impatient!!! lol
    Cut and have mounted the passenger side bracket and first piece of top tube to start lining things up from and tack as I go etc ...
    Gangs of fun!!!!
    Placed the bumper stop back on (just sitting there) and will need to do something with this gap - not overly concerned with it just yet though ...
    Top tube position from the bracket - still let's me get at the bolts (which I've cleaned up and coated with anti-seize ...
  7. #586
    Feb 2011
    Shed
    45 Post(s)
    Shes comin together mate exciting times to come! Are ya gunna be there when Tank goes under the chop?
  8. #587
    Oct 2010
    Quote Originally Posted by growlers71gq View Post
    Thanks mate - yep, will be the support person when the knife gets taken to him!! lol ... pretty excited about it now ... dhuck is coming over tomorrow also, so we should be able to knock out the bar work this weekend at least ready for final fitting after the chop chop ...
    EDIT: painting it 'pot belly' black!!
  9. #588
    Oct 2010
    Tatura VIC
    Sounds good mate, can't wait to see how it turns out
    Apprentice Sparky
  10. #589
    Oct 2010
    Couple more progress shots (not much progress though!! lol). Have just tacked the top bar on to get the angle for the bottom tube ... at the join on the corner, both tubes run down the car together with the outer edge of the smaller one sitting about 30mm inside the outer edge of the larger tube to sort of 'taper' it in line with the body and not look too boxy ...
    Tomorrow is another day, so the welder has been put away for today!!
    Holding the bottom tube just to give you the idea of where it runs from/to ... pretty stoked that my angle cut to the mounting plate (by hand with the angle grinder) was bloody spot on!!! Miracles will never cease!!! lmfao
  11. #590
    Feb 2011
    Shed
    45 Post(s)
    Thats comin on reeeel nice. What if anything are you gunna put in the open ends mate
