Results 1 to 6 of 6
Thread: Td42 idle at warm temp
    Sep 2025
    Hey, Gents!
    My TD42 IDLES REALLY HIGH AT OPERATING TEMP (1000+ rpm)
    When switched off for a while, goes back to normal idle then proceeds to high when warm.
    When revved at warm temp, idle would not come down. Stays at certain RPM where you pulled your foot off the gas.
    Is it safe to say that i need an IP rebuild?
    Apr 2021
    Brazil
    Check if the accelerator cable is not holding the IP lever at an accelerated position. Try returning the accelerator lever at the IP by hand.
  3. The Following User Says Thank You to BrazilianY60 For This Useful Post:
    mudski (23rd September 2025)
    Yep, remove the cable to the pump and see what happens.
    Patrol Freak jff45's Avatar
    Morayfield, QLD
    The high idle can happen when someone plays with the fuel screw. You can't back off the throttle lever enough to compensate for the higher idle.
    John
  6. The Following User Says Thank You to jff45 For This Useful Post:
    BrazilianY60 (24th September 2025)
    Feb 2012
    Is the AC idle-up circuit working correctly?
    Sep 2025
    Has the pump ever been serviced before?
