Page 74 of 76 FirstFirst ... 7273747576 LastLast
Results 731 to 740 of 753
Thread: Jay see 1997 GU build up
  1. #731
    Quote Originally Posted by BigRAWesty View Post
    Geeze that's going to be one very loaded roof!! Shame the bar isn't done though!!
    The cans will be empty most of the time, will fill them when needed and empty into the tank as soon as I can. The tyre, well got nowhere else to put it.
    Yeah, pissed about the bar. Millweld have no communications, it's like when it's finished you will get it..
  2. #732
    Gvm upgrade...
    Got priced at $5450, ouch...
  3. The Following User Says Thank You to jay see For This Useful Post:
    Touses (10th August 2024)
  4. #733
    Jun 2018
    25 Post(s)
    Gvm upgrade...
    Jeez. The only thing that won't be a problem with weight is the wallet!!
  5. The Following User Says Thank You to Cremulator For This Useful Post:
  6. #734
    Guys I need some help in naming this part.
    It sits between the maf sensor and the intake pipe, as you can see it's f@#ked.
    Cheers..
  7. #735
    Wow I seriously need to update this.
    But first can anyone explain what's going on here please..
    https://youtube.com/shorts/f_gMU_aqo...ryC0sEjk6Cupeq
  8. #736
    177 Post(s)
    The display unit of your shunt seems cooked mate.
  9. The Following User Says Thank You to Hodge For This Useful Post:
    jay see (6th September 2025)
  10. #737
    Another little problem came up today.
    1st cruise control wouldn't go on, the switch doesn't feel right, so I guessing that has something to do with it. Then I lost most of the dash, this happened 3 times each for around 10-15 minutes and each time everything came back good.
    The photo was taken at 100 km/h.
    Is it possible that the 2 are related?
  11. #738
    I did have the dash fail on me in my 07gu before I sold it. For some reason on the road at 100kmh the dash just died. The fuse had blown.
    I'd check fuse first and then earth points.
    If the 2 circuits use the same earth point it could well be related..
  12. The Following User Says Thank You to BigRAWesty For This Useful Post:
    jay see (7th September 2025)
  13. #739
    Going to go through all the fuses tomorrow
  14. The Following User Says Thank You to jay see For This Useful Post:
    BigRAWesty (8th September 2025)
  15. #740
    Just thinking about this and if a fuse was blown it wouldn't have come back good. Earth maybe, but have no idea where to start.
    Think I'll pull out the switch 1st..
  16. The Following User Says Thank You to jay see For This Useful Post:
