G'day. Sorry for the tardy reply. I have had to modify the heat shield to fit over the headers. An upside down tray with one edge cut off should work. Just use a holesaw to cut a hole and fit an appropriately sized upright pipe a couple of inches to the rear of the filter housing inlet. Most auto shops sell the flexible aluminium ducting you need to pipe hot air into the inlet.
I used U bolts to secure the collector onto the header pipes. From memory there are mounting holes in the factory manifold.
I also have two small sections of hose to fit the diaphragm. One has a small ball bearing forced inside, and is identified with a small blue cable tie. I use that on to stop the diaphragm from operating in warmer weather or on long trips.
When it gets cold I swap out the hoses so the carby warms up faster. It saves a bunch of fuel , because the device on the filter housing seems to allow the hot air to operate too often.
