What size is the leaking hose? What type of hose are you using also? And what clamps are you using?
As for the Redarc LWS. Since replacing the clip i have had no issues. I just used a insulated female blade terminal and cut a section out of the insulation so the termical could be fitted to the round head on the sensor. So far so good....
