Results 1 to 5 of 5
Thread: Ocam mirror stuck
    Ocam mirror stuck
    Hi Folks,
    I picked up some second hand Ocam mirrors and put them on.
    The drivers side is stuck, you can’t manually push it in.
    Passenger side is fine.
    I’m not using the electrics, just manually moving.
    Is there something I’m missing here?
    I’ve tried a bit of force but I don’t want to use extreme force and break it.
    Alrighty then, scrap this post, it just needed some extra ooomf lol
    Let me guess, you hit it with your largest handbag?
    Glad that worked out, can you adjust the mirrors without the electrics?
    Yep you can but just have to be very careful adjusting the mirror itself. Its all set up perfect now and probably won't need to adjust again.
  5. The Following User Says Thank You to AB For This Useful Post:
    PeeBee (7th April 2025)
    I have the same mirrors on my GU but the narrow version of them. So much better to look out of those than the standard mirror. and yes even mine take a bit of a push...
