Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: 2012 GU CRD running a little warmer than usual.
    Yea, Victoria
    This is proving to be a night mare. There are four nuts and studs that hold the viscous clutch to the water pump. I got two of those off with no issues. But the last two refuse the budge. Now one of them is nicely rounded off.... FFS. Looks like a angle grinder cutting disk is my last resort. But I plan on having a cold ale or two and think about it first......
  2. The Following User Says Thank You to Coldcomfort For This Useful Post:
    mudnut (2nd January 2025)
  3. #12
    Yea, Victoria
    New pump and viscious coupler installed. Took a while to burp the system but all good now. Has anyome had a shit time getting the nuts of the pump/coupler flanges? I had to use a angle grinder for two of them. Nuts made of butter.
  4. #13
    Nov 2019
    Perth
    5 Post(s)
    I tried getting those nuts off once and nearly rounded them too, I left it thinking I would upgrade the pump & hub at a later date
    2008 CRD Auto Wagon
  5. #14
    Yea, Victoria
    The issue is that there is not enough room to get a good 6 point ring spanner in. I had to use a open end spanner. Two nuts cam off relatively easy. The last two were complete bastards. If anyone has to do this be prepared to replace the water pump along with the coupler.
  6. The Following User Says Thank You to Coldcomfort For This Useful Post:
    mudski (20th January 2025)
