Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 41
Thread: Post pictures of your battery terminals. The good, bad and ugly
  1. #31
    Patrol Guru firm351's Avatar
    Jun 2013
    Mundijong, WA
    4 Post(s)
    Rewire the winch for a start. If you don't have one then buy a proper crimping tool and also proper cable shears.
    No winch mate but i might have to get one now so the cable doesn't go to waste, see if the mrs buys that one. Got all the crimping and cutting gear at work so ill just borrow that for now.
  2. The Following User Says Thank You to firm351 For This Useful Post:
    MudRunnerTD (1st May 2017)
  3. #32
    Patrol Freak Mc4by's Avatar
    Oct 2016
    Mandurah W.A.
    7 Post(s)
    As a newbie to the 4wd fraternity I am wondering what it is that you all have attached to your batteries!!!!!
    So many connections.
    Please tell me what you are running in your rigs.
  4. #33
    Now I've seen some mighty and interesting busbars in my industry, but this one takes the cake ol' Phil. lol
    I am an innovator!
  5. The Following 2 Users Say Thank You to PeeBee For This Useful Post:
    Hodge (2nd May 2017), VK2FMIA (1st September 2017)
  6. #34
    177 Post(s)
    Quote Originally Posted by Mc4by View Post
    Not much in my rig.
    Led bar, compressor, winch and the redarc bcdc are hanging off my main battery.
    Second battery has the fridge, rear light , UHF unit and the main stereo.
    Just waiting for @PeeBee s response to this
    Mc4by, my photo is a bit of a piss take!
    Re accessories I am a little over the top I guess.
    I run aux ignition fuse boxes and also 3 aux accessory fuse boxes to try and keep the wiring neat and reduce the firewall penetrations to a minimum, as this is where you can run into trouble with chaffing and shorting wires, unless you use the correct glands to feed the wires thru.
    Regards devices, Communications( 27mhz, HF, uhf, vhf amateur, vhf marine, Satellite phone, GSM phone), 240VInverter for power tools, coffee machine, power off for fridge, aux. lights for camping and driving, winch supply, various instruments like volt meters, EGT, water and oil temp. Its pretty busy under the bonnet and dash!
    It important to remember to fuse all cables and ensure the fuses are the correct rating - they are there to protect the device, wiring and eliminate fires.
  8. #36
    This is my van..
    Car is a similar setup (less solar controller and is hidden under draws..)
  9. The Following User Says Thank You to BigRAWesty For This Useful Post:
    PeeBee (2nd May 2017)
  10. #37
    Aug 2017
    Well my my main plan for today didn't work but at least I tidied up the battery terminals a little
    Where did you get the wire that you've got coming off the right of the positive terminal, looks braided?
  11. #38
    Nov 2024
    Queensland, Australia
    here is what I have recently inherited
    Main Battery Carrier
    secondary Battery Carrier
    and there are two Solenoids which I have yet to see what they are actually connected too
    Front solenoid
    Rear Solenoid
  12. #39
    Expert Brissieboy's Avatar
    Jul 2015
    Brisbane, Qld
    10 Post(s)
    An old klaxon horn - don't see (or hear) them much these days although modern copies are readily available. They were popular way back when . . . I used to have one on my FL Holden.
  13. The Following 2 Users Say Thank You to Brissieboy For This Useful Post:
    BrazilianY60 (9th December 2024), Plasnart (8th December 2024)
  14. #40
    Quote Originally Posted by Brissieboy View Post
    Aroooga! Yes I was going to say the same thing.
    Pull it out, follow the wires and pull them all out. Are the solenoids connected to the klaxon wiring?
    Get rid of all that shit and put in a quality La Cucaracha!
    Gong him Red!!
  15. The Following 2 Users Say Thank You to Plasnart For This Useful Post:
    BrazilianY60 (9th December 2024), PeeBee (9th December 2024)
