Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: GQ Gearbox question
    Nov 2011
    how different are the diesels to the petrols in the gq
  2. #12
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    Quote Originally Posted by poltac View Post
    You might want post this question up in a new thread
  3. #13
    Oct 2024
    Unhappy
    You don't need a spring compressor, you can make one up yourself, but in saying that a bought spring compressor would of made my gearbox rebuild a whole lot easier.
    Now you tell me I should of bagged and tagged all the parts!!!!
    If you do it yourself I will suggest you also measure the springs and write down what clutch pack it came out of just in case you get things missed up, my springs didn't match the manuals specs and a lot of guess work was involved!!!
    Hellow wayflyer mate I’m in Perth also!
    I recently bought a gq with a vh41de that had a blown box. I had another box to go on fit that and nothing!,
    Had no drive at all when I pulled it off again I noticed the input shaft was longer they had welded spacers to the flex plate, and extended the located lug on the torque converter had been extended. It appears they retained the re401A input shaft and torque converter, I replaced the input shaft and refit buut soon as I warmed the car up she pissed tranny fluid out the bellhousing! I think I mighta pinched the pump seal so out it comes again.. my question is other than that was there anything else you had to modify for it to work? I’ve hit a wall here any help would be greatly appreciated
  4. #14
    Oct 2024
    hey mate I’m in Perth too
    I recently bought a gq with a vh41de lic with a blown box, per the paperwork it said oem transmission was retained nothing mentioned about any mods what did you have to do to get yours to work?
