Results 31 to 36 of 36
Thread: GU centre console removal
  1. #31
    Nice glove box @Cuppa. Where you buy that from?
  2. #32
    178 Post(s)
    Not sure, it was either the Cuppski Corporation or the Mudpa Association.
  3. #33
    I like the sound of Cuppski Corp. I will look them up.
  4. #34
    Expert Mike02Ti's Avatar
    Jun 2016
    Rockingham WA
    4 Post(s)
    Thanks Mark & Mike, have just ordered one from my local Jaycar outlet. New model - will take 3 days to get it in. Comes with panel & surface mount & looks like it should fit the same as the existing one.
    Older model with same 4.2a output is on special at the moment, but I wasn't sure if it had the same mount as my existing one - so paid a bit more for the new one which does. Probably a good buy for anyone who doesn't need the extra 'plastic surround' though.
    Photo of my existing one, just 'cos I'm not sure which is the 'Panel' mount, & which is the 'Surface' mount, although I'm guessing mine is 'Panel'.
    Attachment 72251
    Both "should" fit your existing panel by the looks of it. Same screw type mount on the back judging by the pics.
    I had the older type which works well. Stuck it in the back for the 3rd row seat.
    The other ones i have are the carling switch lookalike ones which are mounted where the rear ash tray used to be. Both types work well imo
    2002 GUIII Ti 4.8
    Details here
  5. #35
    Sep 2024
    Hi all,
    I just rejoined your group.
    My handbrake on my 2007 GU is faulty.
    I have pulled out the centre consol and cleaned up the dirt.
    This is what I have.
    Handbrake just does nothing when applied so maybe broken cable.
    Also, how do I post pucs please
    My problem car is unregistered so I can't take it to a mechanic.
    Anyone in Southern Adelaide what to assist ???
    Regards
    Oldmadmax800
    John W
  6. #36
    84 Post(s)
    Quote Originally Posted by Oldmadmax800 View Post
    Hi all,
    Regards
    Oldmadmax800
    John W
    Welcome back to the forum. To post pics, use the GO Advanced button at the bottom right of the post window. Press the Paper Clip Icon at the top of the post window. Choose file. Find and select a file and then upload the file. Just remember to shrink your picture files . I usually resize them to around 1500 x1000. You can preview your post too. This is the resultant quality of a Jpeg file.
