Results 1 to 6 of 6
Thread: Batteries
    May 2024
    AUS
    Batteries
    Hi,
    With all the mods on my truck I'm 80Kg's away from my max GVM (half a tank & no passenger) & want to tow a caravan so I'm looking to save some weight. I'm considering switching to Lithium batteries as one option for a few Kg's in savings. Are the cheap Kings one's reliable enough to choose? Also what brand would people recommend instead if they are not a good choice?
  2. The Following User Says Thank You to T0B3R For This Useful Post:
    MB (2nd June 2024)
    Nov 2019
    Perth
    5 Post(s)
    for aux/deepcycle have a look at the Itechworld batteries, they are designed for underbonnet use
    for cranking, stick to lead acid
    2008 CRD Auto Wagon
    Feb 2012
    Changing battery type is just tinkering around the edges.
    You say you're already nudging max GVM (looks over to me..).
    If you want to tow, you'll need to upgrade the GVM.
    Been there....
  5. The Following User Says Thank You to geoffayres For This Useful Post:
    AB (31st May 2024)
    One of the first things i did to my Y62 was swap out the cranking battery for a DCS Lithium under the bonnet, there is a fair saving. The Y62 has a weight restriction on the front making every kg count.
    Quote Originally Posted by geoffayres View Post
    Been there....
    I agree with Geoff, if you’re chasing that kind of weight difference then you are done. Batteries won’t change a thing.
    GVM unfortunately if you are chasing such a low improvements in weight unfortunately.
    Nov 2019
    Perth
    5 Post(s)
    didn't know lfp cranking batteries existed, reading up on them now
    2008 CRD Auto Wagon
