Page 1053 of 1057 FirstFirst ... 10511052105310541055 ... LastLast
Results 10,521 to 10,530 of 10566
  1. #10521
    More or less finished the POD electrics today, debating whether I stick with the breaker panel or just run have short extension leads instead to the other side of the POD - bit extravagant with the separate panel I think.
    Sorted out the lack of charge today, was missing a common earth, now rear batteries are charging, via the BCDC, solar and direct off alternator. Painted the sliders on the underside, taking two days to dry with the cold weather. With luck will get it out for a squirt down the highway before going back to the mine for a month straight - not looking forward to that.
  2. The Following 5 Users Say Thank You to PeeBee For This Useful Post:
    AB (24th May 2024), BrazilianY60 (24th May 2024), Cremulator (25th May 2024), MB (25th May 2024), Stropp (24th May 2024)
  3. #10522
    Patrol God Stropp's Avatar
    38 Post(s)
    Good luck mate hope she performs perfectly 👌
  4. The Following User Says Thank You to Stropp For This Useful Post:
    MB (26th May 2024)
  5. #10523
    Thanks Stropp, spent another big day on the barge, stuffing around and doing things once properly, 240V system now installed, double Makita 18V battery charger installed, on board Victron 240V charger installed, fitted the remaining pod anchors today, sorted out the coolant leak which was a loose clamp, need to sort out one more POD rear wall penetration, and fit a fuel isolation valve, then it will be on the final run. I have a number of hydraulic hoses under the car for the winches and they really need some robust supports. Off to the mine again for a month this time, so will address when I get back. Simply ran out of time today, and the temps plummet after about 5pm, so headed inside for a beer.
  6. The Following 4 Users Say Thank You to PeeBee For This Useful Post:
    BrazilianY60 (27th May 2024), MB (26th May 2024), Stropp (25th May 2024), Touses (26th May 2024)
  7. #10524
    Hahaha forgot about this, I haven’t been able to get on roads for 110 but I did a naughty local 100kmh and it was 2400.
    It’s up there at 110. I’ll get alternator sorted this weekend and take it for a run.
    2600-2650 at 110kmh
  8. The Following User Says Thank You to AB For This Useful Post:
    MB (26th May 2024)
  9. #10525
    483 Post(s)
    Just got word, a piccy too, from my newfound weekend Legendary Lady panel beater.
    My GQ guards are ready for CK0 code paint tomorrow & Tuesday:
    Ended up cheating and outsourcing a TIG welder Legendary Lad too for reconnecting my wacky trimmed idea:
    Tried my best with the Shed MIG and gave up……if it aint 10mm thick and 200+ amps I am a horrible welder
    These replacement guards for my Tassie munted ones sound like they’ll be getting used across the Simpson Desert/Mud Trek soon
    Was hoping to run my 33” All-Terrains, might have to keep the 36” Simex on instead
  10. The Following 8 Users Say Thank You to MB For This Useful Post:
    AB (2nd June 2024), Bidja (2nd June 2024), Cremulator (2nd June 2024), MudRunnerTD (2nd June 2024), PeeBee (2nd June 2024), Plasnart (2nd June 2024), Rossco (2nd June 2024), Stropp (2nd June 2024)
  11. #10526
    Look great Mark. My crossing of the Simpson was with mud terrains and I didnt get any further in the goop on the Strezleki than the guy with all terrains in all honesty, sticky power sapping muck, no friction, no go forward.
  12. The Following 2 Users Say Thank You to PeeBee For This Useful Post:
    MB (2nd June 2024), Stropp (2nd June 2024)
  13. #10527
    483 Post(s)
    Cheers Philstar
    I’ll leave my DazWing Sand/Mud anchor aboard then should we?
    Can I pretty please borrow your 33” ladder chains too
  14. #10528
    483 Post(s)
    My professional lacking painting Agri-efforts……gotta love high temp pressure pack cans built for turbo/intercooler experimental Nuffy’s
  15. The Following 4 Users Say Thank You to MB For This Useful Post:
    mudnut (2nd June 2024), MudRunnerTD (2nd June 2024), PeeBee (3rd June 2024), Stropp (2nd June 2024)
  16. #10529
    Woulda looked better in Pink
  17. The Following 3 Users Say Thank You to MudRunnerTD For This Useful Post:
    AB (2nd June 2024), Cremulator (2nd June 2024), MB (2nd June 2024)
  18. #10530
    483 Post(s)
    Get stuffed Poof
  19. The Following 3 Users Say Thank You to MB For This Useful Post:
    Cremulator (2nd June 2024), MudRunnerTD (3rd June 2024), PeeBee (3rd June 2024)
