Page 73 of 77 FirstFirst ... 7172737475 ... LastLast
Results 721 to 730 of 762
Thread: Jay see 1997 GU build up
  1. #721
    483 Post(s)
    @PeeBee Philstar, what would happen if @jaysee Brother installed a tyre valve in the cap instead of a breather and linked up his onboard air compressor to force water out of its lowest point gravity tube? Could the air pressure Archimedes style push every last droplet uphill to a comfortable collection height?
    Cremulator (23rd May 2024)
  3. #722
    Yep, but the increase in pressure only needs to be a poofteenth to generate massive velocity out the nozzle ( 5PSI across the total area of the tank is a massive discharge force.). What I dont like about that idea , is the water jet is going to be very fast so more splashy and likely to waste more than say a steady stream via gravity, plus you need to switch it off pretty quickly as the pressure will build fast and get progressively worse - FAST.. I guess if you want to wash a car or similar the added velocity which will equate to volume is fine but for a billie fill or a quick wash of the hands , slow and steady would be my pick. I think I have mentioned before that Jenny and I burned thru 30L in two days at dalhousie because it was 28 deg and the springs well above that, and we didn't waste any, decanted it from a jerry with a hand pump. The electric pumps are a quick way to lose track of your fixed water storage in my view, but you know, its connected now, and there for a reason and choice, it works, get used to it I guess and see how it goes - easy to convert to gravity if it becomes a problem.
    Regards the discharge height, well my water tank hoses hand out the door and terminate about 8" off the ground so pot filling and hand washing is not too bad. - Just a comparison but maybe work considering also as pots are on stable ground as well instead of trying to do the octopus 5 arm shuffle.
  4. The Following 2 Users Say Thank You to PeeBee For This Useful Post:
    Cremulator (23rd May 2024), MB (22nd May 2024)
  5. #723
    483 Post(s)
    Apologies @jaysee
    Philstar, what if the air compressor (onboard always and needed offroad anyway) was permanently connected to a water tank with a basic pressure small lightweight valve/regulator? Of course the hose sump/outlet would need a severely reduced end on it with a valve/tap for water trickle if needed careful saving or high pressure squirting potential?
  6. #724
    No need to worry about it guys, no on board compressor..
  7. The Following 2 Users Say Thank You to jay see For This Useful Post:
    MB (22nd May 2024), PeeBee (22nd May 2024)
  8. #725
    Apologies @jaysee
    I would run a pressure regulator limited to no more than 5psi. Anything more and the tank could split. Running pressure in a plastic tank is asking for problems.
    MB (22nd May 2024)
  10. #726
    483 Post(s)
    Apologies John Mate, I take full blame for bastardising temporarily your Build Thread Brother
    Pictorially, in sequence, I guess this is what I was trying to suggest to Philstar:
    The first three (3) photo examples are similar to what we use at work to connect to mains water garden hoses to vary between taking a trickle sip of water when thirsty in the yard to also carefully blasting truck radiators or full tilt mud blasting pinpoint out of their tipper corners at a long distance etc…
  11. #727
    Yep, I get it, but NO, leave it as it is if you want the pump and pressure would be my recommendation.
    MB (23rd May 2024)
  13. #728
    Well I've done it again.
    Electronics and me have a long battle before we're both on the same page. This time I brought a kickass battery monitor
    https://kickassproducts.com.au/produ...waAudQEALw_wcB
    It seems to look like I'm only going getting volts. I had a fridge and the freezer both on and compressor running on both when I took the picture and still showed just about no amps.
    Negative on the battery to -B on shunt and -P on shunt to ground (metal body)
    Have I got the -P side of the shunt correct?
  14. #729
    Well it looks like my rear bar isn't going to make the big trip. From a completion date of the 16th to the 18th to the latest today, it's still not finished. I went out and spent some.
    Main reason was to carry 2 Jerry cans, that's not going to happen so I went out today and updated my rack to carry the cans, a spare tyre, maxtraxs and what whatever else I what to throw up there.
    While out today picking up things all over the place I also got a bushwakka 270 awning.
    With eofy savings it was a good time to upgrade.
  15. The Following 4 Users Say Thank You to jay see For This Useful Post:
    10G (26th June 2024), BigRAWesty (25th June 2024), MB (26th June 2024), PeeBee (25th June 2024)
  16. #730
    Geeze that's going to be one very loaded roof!! Shame the bar isn't done though!!
