Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: 15V to 14.8v AGm battery - Too high?
    178 Post(s)
    Agree with Winnie.
    It’s the fact that something has changed which is of concern.
  2. The Following User Says Thank You to Cuppa For This Useful Post:
    AB (19th May 2024)
  3. #12
    For sure, I’m definitely not saying it’s ok.
    I might even just take it to an auto elec to properly check out to be sure.
  4. #13
    Like Dazz said my money is on regulator.
    It happened in Toolangi when I first got the Gq and my battery looked like a balloon!
  5. #14
    482 Post(s)
    If ever Suspect on an integral part, replace with new and keep the Suspect as a spare….onboard in this Adventure scenario
    Will also immediately diagnose itself once the new part is installed
  6. #15
    482 Post(s)
    FWIW: Been running Optima yellow tops D27 & 31’s for well over a decade. Not saying they can’t handle it but have never personally ever had a TD42’s alternator, Jaylec, Baxters, Quickazz ever go beyond 14.8v prior to sludge bastardisation or after.
  7. #16
    Unfortunately it looks to be the regulator which was expected.
    Very lucky in hindsight as ive been driving it to work recently to ensure its reliability before the big trip so thats bloody lucky it happened here!
  8. The Following User Says Thank You to AB For This Useful Post:
    MB (21st May 2024)
  9. #17
    Apr 2021
    Brazil
    Yep, always need some shakedown runs, even some small trips if possible.
  10. The Following User Says Thank You to BrazilianY60 For This Useful Post:
    AB (22nd May 2024)
  11. #18
    Nov 2019
    Perth
    5 Post(s)
    I did read though it could be a faulty Earth or Neg point. disconnect the battery and disconnect the earth off the Alternator and clean and reconnect and see if that fixes it.
    Good point. The earth is probably the most overlooked asset of any vehicle.
    2008 CRD Auto Wagon
  12. The Following User Says Thank You to pollenface For This Useful Post:
    MudRunnerTD (22nd May 2024)
