Page 1050 of 1057 FirstFirst ... 10481049105010511052 ... LastLast
Results 10,491 to 10,500 of 10566
  1. #10491
    177 Post(s)
    Anyhoo!
    Does anyone have a spare 5spd lying around. 4k for a new box and another 1k to get it fitted. Im trying to find a low K second hand box but not having much luck.
    It might stay a 4spd for a while longer I think.
    Ring places that possibly do engine conversions etc... There's a LOT of barra conversions going on. Therefore a LOT of redundant gearboxes laying around somewhere.
  2. The Following 3 Users Say Thank You to Hodge For This Useful Post:
    MB (8th May 2024), MudRunnerTD (4th May 2024), PeeBee (4th May 2024)
  3. #10492
    Thats a great idea. Or @mudski join a Barra conversion group of FB and ask if anyone has a gearbox in the shed.
  4. The Following 2 Users Say Thank You to MudRunnerTD For This Useful Post:
    MB (8th May 2024), PeeBee (4th May 2024)
  5. #10493
    What are the chances!
    I replaced the fuel filter a while back and noticed the lift pump wasn't holding pressure anymore.
    It would need a good 20 pumps if left sitting for the night.
    Ok, easy, it has to be what I have just done. Check bleeder, check drain, check fuel filter, etc.
    Everything looks fine. I took it off and on again multiple times.
    I have never had a problem with my fuel pressure.
    I just found this whilst waiting for Mia's school bus. That little tiny injector bleed return line looks to be the culprit.
    What a perfect time for that to happen exactly the same time as I replace the filter!!!
  6. The Following 2 Users Say Thank You to AB For This Useful Post:
    MB (8th May 2024), Stropp (9th May 2024)
  7. #10494
    All good. I found a s/h box from a 2008 low 100thou on the clock box. George will be doing the r & r for me. Now I'm thinking do I get the Mark 10% overdrive reduction gear now, since I have saved over 2K. This would bring my revs at 100kph from 2450 to 2205rpm.
    Hmmm.
  8. The Following 2 Users Say Thank You to mudski For This Useful Post:
    Hodge (8th May 2024), MB (8th May 2024)
  9. #10495
    Hmmm.
    I would for sure.
    I struggle on freeways, the Simmo trip will not be fun for me @ 110kmh
  10. The Following 2 Users Say Thank You to AB For This Useful Post:
  11. #10496
    Hmmm.
    Mark, I have this conversion and I am now sitting in the sweet spot for max economy at 110klm/hr at 1750rpm.Unlike the 85% reduction gears that howl all day in low range the machine finish is excellent on the overdrive gears - silent as stock standard.
    MB (8th May 2024)
  13. #10497
    483 Post(s)
    What did you do to your Patrol today!
    Mocked up with black tape, another Wacky MB concept
    Not sure if I love it or hate it yet
    Keen for your honest helpful thoughts prior to welding Team NP.com.au?
    Certainly will keep I believe our pesky local Hills bugs from ram feeding into the airbox, open passenger side window for a Navi would be a lot more bearable too I imagine
    The 30 degree downwards, slightly twisted final bend theory is for parked up outside/overnight camping torrential rains protection.
    Have had previous plastic family GU wagon truckster ram head snorkels fill airboxes overnight and believe poor @Rossco ‘s GQ once did the same nearly hydro-locking his beast on morning startup
    EDIT: Besides looking a little kooky, not powder coated yet Could the extra nearly say 800mm of 4” pipe potentially hinder its air intake? I’m only chasing 150rwkw again
  14. The Following 2 Users Say Thank You to MB For This Useful Post:
    BrazilianY60 (8th May 2024), PeeBee (8th May 2024)
  15. #10498
    Looks good, the extra pipe length would add restrictions in the order of 4 decimal places - not an issue, clever about the drop end to keep the water out. I have never had a problem with my forward facing safari head, or maybe the water simply was very small and evaporated from bonnet heat?
  16. The Following User Says Thank You to PeeBee For This Useful Post:
    MB (8th May 2024)
  17. #10499
    Apr 2021
    Brazil
    Do you have a link for this reduction? I don't even have the power to push current 5th gear yet, but this is an interesting thing to know it exists.
  18. The Following User Says Thank You to BrazilianY60 For This Useful Post:
    MB (8th May 2024)
  19. #10500
    Here you go
    https://www.marks4wd.com/low-range-overdrive-gears
  20. The Following 3 Users Say Thank You to PeeBee For This Useful Post:
    BrazilianY60 (9th May 2024), MB (8th May 2024), Rossco (10th May 2024)
