Page 1048 of 1057 FirstFirst ... 10461047104810491050 ... LastLast
Results 10,471 to 10,480 of 10566
  1. #10471
    Fitted the hydraulic hoses for the winches thru the air fed cooler, another fiddly tight as hell job done and dusted. Struggling with the effects of going onto blood thinners and every knock and scrap sees bleeding like a stuck pig, unsure what the neighbours and passers-by are thinking as it doesn't stop me, but end up looking a bit lick Mel Gibson after a bit in braveheart!
  2. The Following 4 Users Say Thank You to PeeBee For This Useful Post:
    BrazilianY60 (5th April 2024), Cremulator (5th April 2024), MB (5th April 2024), mudnut (6th April 2024)
  3. #10472
    Nearly done this simple setup. Will be a touring setup and a full time 50ltr weaco fridge.
    110ah agm in the fron of the draws.
    Kickass 25A dcdc charger with solar input.
    Victron shunt.
    EBay 8 switch panel to run it all.
    I've added bus bars for future expansion but probably overkill lol.
    3 cables running to the right are for a remote panel which will house 4 usb ports, 2 cig sockets, solar input anderson plug and a power anderson plug to run a remote power board for in tent charging, or a 240v charger input if needed..
    The 8 gang switch panel is a solid bit of kit.
    The board is resin filled, 60A capacity.
    And Bluetooth app connectivity which works well..
  4. The Following 5 Users Say Thank You to BigRAWesty For This Useful Post:
    10G (15th April 2024), Cremulator (14th April 2024), jay see (14th April 2024), MB (13th April 2024), PeeBee (13th April 2024)
  5. #10473
    Switch panel added.
    At this stage button 7 and 8 controll each cig socket / usb panel each.
    Button 1 is the fridge.
    Button 2 is the top anderson.
    Button anderson is solar input to kickass charger..
    The Bluetooth app works a treat!!
    For $200 I'm over the moon with it!!
  6. The Following 4 Users Say Thank You to BigRAWesty For This Useful Post:
    10G (15th April 2024), AB (15th April 2024), Cremulator (14th April 2024), MB (15th April 2024)
  7. #10474
    Jun 2018
    25 Post(s)
    Quote Originally Posted by BigRAWesty View Post
    Switch panel added.
    Looks great! Nice work
  8. The Following 2 Users Say Thank You to Cremulator For This Useful Post:
    BigRAWesty (14th April 2024), MB (15th April 2024)
  9. #10475
    Well after leaving home at 10pm Tuesday night to get up to SW QLD to get my daughter away from this toxic and abusive environment she’s called home and work for the past six weeks, at 5am, 240k south of Cobar fifth gear let’s go. I limp into Cobar, not one workshop would help. All I want was to drop the oil, and refill with fresh oil. So I did it on the side of the road. Four hours later I’m off again.
    Slow driving as 90 was absolute max I can go in 4th.
    Get to Bourke to head further north, roads are shut due to flooding. I was told of a back road which will get me to Thargominda, long, dirt road but not flooded. I finally pull in at 9pm, driving pretty much non stop since 10pm the night before.
    Get a room, sleep for 12 hours, get up, get in the car, start to move and the sounds from under the Patrol were worrying. I find the only mechanic in town, and this guy was kind enough to drop the oil again and inspect it.
    To cut the story down a little, it’s getting a good second hand box in it tomorrow as I still have to go east to Charleville, drop the daughter off, hook up the horse float from there, and take it with another horse down to Goodiwindi, drop both off there and then head home.
    So a lotta k’s I still need to cover.
  10. The Following 12 Users Say Thank You to mudski For This Useful Post:
    10G (18th April 2024), AB (18th April 2024), BigRAWesty (18th April 2024), BrazilianY60 (18th April 2024), Cremulator (18th April 2024), Hodge (18th April 2024), jay see (18th April 2024), jff45 (24th April 2024), MB (18th April 2024), mudnut (21st April 2024), Plasnart (18th April 2024), Touses (18th April 2024)
  11. #10476
    Bloody hell Mudski, I hope your daughter’s ok!!!
    My boys going through bullying at school at the moment and it makes your blood boil that’s for sure!!!
  12. The Following 3 Users Say Thank You to AB For This Useful Post:
    BrazilianY60 (18th April 2024), MB (18th April 2024), mudski (21st April 2024)
  13. #10477
    Apr 2021
    Brazil
    Good luck Mudski. I hope you get to your daughter quick and safe. Once she is with you mate, take it slow. The "rescue" trip is urgent, but the return home is not. Steam off, take it slow, enjoy each other's company for the way back.
  14. The Following 6 Users Say Thank You to BrazilianY60 For This Useful Post:
    AB (18th April 2024), BigRAWesty (18th April 2024), jay see (18th April 2024), MB (18th April 2024), mudski (21st April 2024), Plasnart (18th April 2024)
  15. #10478
    Apr 2021
    Brazil
    How old are your boys mate? I totally know the feeling and I don't like relying on others to solve my problems (aka asking the school principal to talk to the other family), so don't take this as advice, just venting off here... I once taught my daughter how to break a nose, how to throw a punch to the throat and some other dirty moves and told her to 100% destroy the bully boy with no regrets, that any problem with family or school would be mine to solve, nor hers. It turned out that just giving her that confidence put the thing into a different perspective for the other party without her needing to use the "new skills". But man, did it boiled my blood...
  16. The Following 5 Users Say Thank You to BrazilianY60 For This Useful Post:
    AB (19th April 2024), BigRAWesty (18th April 2024), Hodge (22nd April 2024), MB (18th April 2024), Plasnart (18th April 2024)
  17. #10479
    Fark is this up at the station?
    What a fkd time for the box to let go to!!
  18. The Following User Says Thank You to BigRAWesty For This Useful Post:
  19. #10480
    483 Post(s)
    Please do ‘name & shame’ the culprits on that station @mudski Brother
    Safe Travels you two
