Results 1 to 7 of 7
Thread: Exhaust help !
    Beginner mannyr.2000's Avatar
    Dec 2022
    Exhaust help !
    Hi All
    Recently installed a 3inch turbo back exhaust (with cat & hotdog) in my ZD30CR sounds great runs terrible
    Feels like I've taken a step backwards, less responsive , even bigger turbo lag.
    Been told its actually running in limp mode, but no engine light is on, is this possible ?
    Also been advised a Tillix boost control kit will fix the issue ?
    Appreciate all the help i can get, I'm a noob when it comes to this stuff...
    Thanks all
    Yea, Victoria
    I had the same. You will have to go with a dawes valve set up or risk over boosting your engine.
  3. The Following User Says Thank You to Coldcomfort For This Useful Post:
    mannyr.2000 (6th March 2024)
    Yep. You need to add some manual boost control in now to fix all this.
    Nov 2019
    Perth
    5 Post(s)
    It can run like crap without an error code, I've done it when I forgot to tighten an intake clamp.
    there are two blanking plates available. you can blank at both ends to reduce intake/exhaust turbulence. The intake side goes under the EGR volume control valve (if you're wondering)
    There are various manual boost control options, I have the HPD type only with no needle valve. I have a bung tapped into the steel intake pipe above the turbo for boost reference.
    You have to do both at the same time, blank EGR and manual boost control and as I recently learned keep the vacuum solenoid connected to the wiring harness otherwise it WILL go into limp mode.
    2008 CRD Auto Wagon
  7. The Following User Says Thank You to pollenface For This Useful Post:
    mannyr.2000 (8th March 2024)
  8. #5
    Jun 2024
    Thanks. I will try with a dawes valve set up.
  9. #6
    Check out the video I did for the tillex valve many moons ago.
    https://youtu.be/7tQziIey884?si=SJiWqoCbdMidHl4J
    It's a great setup. I ended up back at 16psi.
    When at 20psi for long runs it dropped into limp mode..
    Here is my original thread I did on it.
    https://r.tapatalk.com/shareLink/top...ink_source=app
    Patrol Freak Bidja's Avatar
    Jul 2017
    Southern Table Lands, NSW
    40 Post(s)
    Quote Originally Posted by lychniscuddly View Post
    There are a lot of copy Dawes boost controllers out there, the only one I trusted was the Dawes 3BarRacing manufactured (Black Body). Does not seem to be available now, lost mine and still sad about that.
    Would buy another if I could get my hands on one.
    Suggest that you buy the Tillix manual boost control kit and check out @BigRAWesty videos.
    https://www.tillix.com.au/product/bo...l-zd30-di-crd/
    BTW drop by the intro section _ say G'day mate
  11. The Following User Says Thank You to Bidja For This Useful Post:
    BigRAWesty (5th September 2024)
