Page 1044 of 1057 FirstFirst ... 10421043104410451046 ... LastLast
Results 10,431 to 10,440 of 10566
  1. #10431
    Righto, another workfront. I had issues fitting the ARB BP51 stone guards. Turned out after ringing ARB, I was missing some small split wedges, however I was not convinced these would work, as others who have the same shocks say they vibrate off, so I modified some motorbike corrigated gaitors and on all 4 shocker rods and they came up well, very happy. ARB were very responsive and sent me express post the parts without issue.Rod Boot 1.jpgRod boot 2.jpgRod boot 3.jpg
    BigRAWesty (28th February 2024)
  3. #10432
    Bloody lovely yeah who would have thought but glad she's good. .
    Sent from my SM-S711B using Tapatalk
  4. #10433
    So reading that correctly, you had the seats out of one car, and the body of another. You had the latches out of both of those cars however neither worked and you required the latch out of the car you own neither the body, nor the seats for?
  5. #10434
    You are correect, what are the chances? I can only assumed I f**cked it all up, per usual, and simply selected the wrong set from the multitude of buckets in the shed. The other brackets, including the ones I thought were my originals must have come from the donor. The shorter ones could only have come from the donor as they were rusty and manky, but from where in the car, dont know. Right now I dont care, the other brackets are already in the bin, never to be mixed up again.
  6. The Following 2 Users Say Thank You to PeeBee For This Useful Post:
    MB (26th February 2024), Winnie (27th February 2024)
  7. #10435
    483 Post(s)
    OCD, has been frowned upon in my nuffy slow moving end game world, bag & slowly tag Legends
  8. The Following 2 Users Say Thank You to MB For This Useful Post:
    BrazilianY60 (28th February 2024), Stropp (28th March 2024)
  9. #10436
    Always someone in the crowd that does it right!!! Yes you warned, yes it stung hard. I also spent 4 hrs trying to find the PTO cover boot, search the world for a replacement, only discovered recently it was already installed and I had forgotten it points into the trans tunnel, not above it, unsure if a tagged bag would have helped, maybe someone with a clear mind instrad of trying to handle 20 things at once. Few lessons from this build, probably none will be learned from though.
  10. The Following 2 Users Say Thank You to PeeBee For This Useful Post:
    BrazilianY60 (28th February 2024), MB (26th February 2024)
  11. #10437
    483 Post(s)
    She’s an Absolute Beast Philstar, almost there and something to be truly PROUD of LEGEND
  12. The Following User Says Thank You to MB For This Useful Post:
    PeeBee (26th February 2024)
  13. #10438
    Already booked in for another lobotomy as there is no chance I am getting talked into doing this again, might even get the ears sewn up as well after they plug 'em with peanut butter!
  14. The Following 3 Users Say Thank You to PeeBee For This Useful Post:
    MB (26th February 2024), Rossco (27th February 2024), Stropp (28th March 2024)
  15. #10439
    Apr 2021
    Brazil
    PB, to you have a build thread of this chopped GQ?
  16. #10440
    I am going to start one. The build has probably been the worst kept secret on the forum in all honesty, but the initial events and ramifications of the event that triggered the rebuild have remained pretty raw for a while, plus I didn't want to get bogged down documenting and reporting whilst building and working. I am about to move the vehicle out of the shed today to 'set it free' and then take it home, once I clear the garage out of all the stuff I have backfilled. The build is conversion of the GQ wagon into a dual cab, with a 1500mm tray , multitude of performance upgrades, which in all honesty are overkill but I had the money so did them.
  17. The Following 2 Users Say Thank You to PeeBee For This Useful Post:
    BigRAWesty (28th February 2024), Stropp (28th March 2024)
