Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: Oztent zipper
    Oztent zipper
    Hi Folks,
    The bloody zipper on the RV5 is not grabbing anymore.
    Does anyone know of any magical trick to get it to work again by chance?
    I’m assuming I need to pull the stitching off at the end to get it to grab again?
    I dunno about the oztent in particular, but I usually just move the zippier up and down furiously while I swear at it and eventually it somehow grabs again?
    I am guessing you have already tried that though!
  3. The Following 3 Users Say Thank You to Winnie For This Useful Post:
    AB (26th August 2023), Maxhead (27th August 2023), Rossco (26th August 2023)
    Yeah I have, I screamed louder this time and it did grab but then came off further down.
    Bugger it!
    It’s bloody Lachy who did this!
    He opens the tent like a menace tearing the two flaps open like a curtain.
    Jun 2018
    25 Post(s)
    I have had success in the past by crimping the zipper with some pliers without removing it from the zip.
    Just try to close the sides that slide along the teeth by putting the pliers on either side of the zipper while it is still in place.
  7. The Following 2 Users Say Thank You to Cremulator For This Useful Post:
    AB (26th August 2023), Avo (28th August 2023)
    I do like that idea.
    I’ll try that, thanks mate!
  9. The Following User Says Thank You to AB For This Useful Post:
    Cremulator (26th August 2023)
  10. #7
    Didn’t work but closer inspection I reckon Lachy has damaged some teeth at the top unfortunately.
  11. The Following User Says Thank You to AB For This Useful Post:
  12. #8
    May 2022
    Tai Tokerau, RD8
    15 Post(s)
    get it closed as high as you can, and a couple stitches with builders string/fishing line/heavy cotton, so the zipper can't go above the damaged teeth...mattress needle or sacking/darning needle do the job
    1989 LWB 5-Seat, TD42
  13. The Following User Says Thank You to mihit For This Useful Post:
  14. #9
    May 2022
    Tai Tokerau, RD8
    15 Post(s)
    And if you can spare the weight, and find someone who still does it, replace with brass zips that will probably outlive your kids...
  15. The Following User Says Thank You to mihit For This Useful Post:
    AB (27th August 2023)
  16. #10
    There’s a few damaged teeth in various places unfortunately.
    There’s a company in Ferntree Gully who repairs these pretty cheap that @MB has used.
    I’ll find out there contact details
  17. The Following User Says Thank You to AB For This Useful Post:
    Stropp (28th August 2023)
