Results 1 to 10 of 54
Thread: Michael's V8Y62
Threaded View
  1. #34
    I am a fan of the airbag replacement coil delete on the back of these. It just makes sense. Infinitely variable continuously adjusting the ride height to the optimum postion for exact Wheel alignment. Adjusts as you use fuel, adjsuts as you take and offload passengers, etc, etc,. Given the wheel alignment is so fickle with these the rear tyre scrubbing is a big deal if you are towing constantly. This is 100% the way i will go on the 62.
    I have not done anything to the front springs for the Rhino bar and Runva winch yet, it seems ok at this point. The winch has Plasma rope and the Battery was swapped out for a DCS80 Lithum so that cgave me back some wieght.
    V8Y62 (19th August 2023)
