Results 1 to 10 of 12
Thread: Hydraulic winch on GQ Patrol - line speeds
Threaded View
  1. #12
    Bit of an update, new PTO hyd pump set up runs at 525rpm and 575rpm depending on PTO position selected. I am running a 70cc pump to drive either a front or rear winch. The front is a 15000lb milemarker and the rear a 20000lb winchmax. The line speed is more than adequate, faster on the front but suspect this is due to the different gearbox ratios. I am waiting on the pressure gauge setup to set the system limits. First observations are very encouraging to say the least. I looked at the speed increasing gearbox route but became too much of a beast to set up.winchmax.jpg
  2. The Following 5 Users Say Thank You to PeeBee For This Useful Post:
    Cremulator (26th July 2023), MB (26th July 2023), mudnut (26th July 2023), mudski (27th July 2023), Touses (26th July 2023)
