Results 1 to 10 of 972
Threaded View
  1. #10
    Jun 2018
    25 Post(s)
    So after last weekend trip, I have no A/C and the thrust bearing for the clutch is screaming it tits off, well since our last Cape Jaffa trip this all started when I stupidly flogged the Patrol in 37c heat with the van in tow whilst using 5th gear. I managed to cook the gearbox oil and ever since the thrust bearing has been noisy, but a whole lot worse now.
    As far as I know, if the A/c is not turning on, its either and electrical issue, blown fuse or broken connection somewhere. Or, its out of gas. So I need to sort that out. Then theres the clutch. No easy way out of this so I will be paying someone to do this. @Alitis007. I'll be calling you soon mate.
    I had to troubleshoot my aircon not turning on too. A mechanic mate of mine helped me and we resolved it in less than 10mins.
    First, take this little cap off and press the valve in *briefly* to check there is gas in the system.
    **It's marked with an L for low, DO NOT press in the side near the radiator marked with an H, that is high pressure**
    If there is gas in the system, it's either a problem with the compressor, electrics or control module.
    My problem ended up being a dirty contact in this terminal preventing the receiver/dryer from switching the system on.
    I cleaned the contacts in this plug with some electrical contact cleaner and it worked perfectly again!
    Hopefully yours is an easy fix too!
  2. The Following User Says Thank You to Cremulator For This Useful Post:
    mudski (21st April 2023)
