Results 1 to 10 of 16
Thread: Wheel Alignment question for smart people
    Ok, trying to do a Cowboy front wheel alignment. Yes yes, I could go somewhere but close enough will do gents.
    Ok, on the hoist and measuring tread block to tread block. Front and back of a 37 Trep.
    Measurements are
    Front 1406mm
    Rear is 1409mm
    Diameter at tread block is 818mm
    Now I think standard Front end alignment is like 2 degrees Toe In.
    The above are a very slight Toe In. I don't want to scrubb out the tyres but keen to get somewhere near factory if i can.
    Any Mathematicians out the can tell me what the measurements should be to be close to 2degrees Toe In.
    Can someone also confirm I'm chasing 2 Degrees Toe In
    Thanks Gents.
    Anyone with Kids doing Year 12 Maths this will be a cake walk for them. Lol
    asin3/818=0.210deg
    But you are running highly unroadworthy tyres and could kill thousands of young kiddies and albatrosses with such an aggressive tyre and big beard. Buy a really big mirror and have a look at what you are doing. I like marmalade curry as well
  3. The Following 4 Users Say Thank You to PeeBee For This Useful Post:
    MudRunnerTD (23rd October 2022), Plasnart (23rd October 2022), Rossco (26th October 2022), Winnie (23rd October 2022)
    Ok mate this is what I worked out. If you look at your wheel from above and turn it 360 degrees with a pen taped to the tread, you'll draw a circle on the floor. This circle will have a diameter of 818mm. You want to work out the length of that circumference for a 2 degree turn. So the circumference of a circle formula is 2 x pi x radius. So your circle is 2 x pi x 414 = 2601.24mm in length. So for every 1 degree slice of that pie, the circumference is 2601.24/360 = 7.23mm. Therefore for a 2 degree toe in, 7.23mm x 2 = 14.46mm. This sounds like wayyyy too much toe in mate, unless I've completely stuffed up the calculation!
    Gong him Red!!
  5. The Following 2 Users Say Thank You to Plasnart For This Useful Post:
    MudRunnerTD (23rd October 2022), rusty_nail (23rd October 2022)
    The spec is a measurement Daz. It's -2mm to 0mm. This equates to anything from 0-9°.
    You also need to be doing the measurement witht the vehicle on the ground. As it will be different on the hoist with the suspension at full droop.
  7. The Following 4 Users Say Thank You to nissannewby For This Useful Post:
    BrazilianY60 (24th October 2022), mihit (25th October 2022), mudnut (23rd October 2022), MudRunnerTD (23rd October 2022)
  8. #5
    You scare me... but you are right!!!! Way too much
  9. #6
    But?? It's the GQ. Suspension will have nothing to do with surely??? A solid front Axle has a controlled fixed length?
    But another note though, so my 3mm is plenty? Too much even? It's 1.5mm per side?
  10. #7
    You still have castor. So the position of the tyres sitting at ride height will be different when the suspension is drooped. If castor didn't exist then you would be fine.
    But yes you are close. You could work back from those measurements. 0.1mm is equal to approximately 0.45°. So if you have -3mm toe then you are at around 13.5°.
  11. The Following User Says Thank You to nissannewby For This Useful Post:
  12. #8
    I have absolutely no comprehension of these figures Matt, 13.5 degrees of what equals 3mm?
    But this is not my thread so ignore if I am an ignoramus.
    Gong him Red!!
  13. The Following User Says Thank You to Plasnart For This Useful Post:
  14. #9
    Just backwards working the numbers. The spec says -2mm to 0mm for the toe. It also states that this is 0-9°. So if 0mm is 0° the -2mm is 9°. Then I just divide that into 20 points so 1 point is 0.1mm. Which equals 0.45°. Darren is at -3mm with his toe adjustment. So 1mm equals 10 points or 4.5° on top of the 9° at -2mm toe.
  15. The Following User Says Thank You to nissannewby For This Useful Post:
  16. #10
    Thanks mate, that's what I was looking for. I will drop it on the ground and try and get it to 2mm. Measuring off treads alone with a tape measure there is almost certainly 1mm in it.
