Results 1 to 10 of 13
Thread: [Vic] TD42 factory low radiator guard/support
    Jun 2018
    25 Post(s)
    Item for sale:
    Factory radiator support/guard for low mount radiator (TD42/TB48)
    Price:
    Make an offer
    Condition:
    Used, excellent condition
    Details:
    Removed because I fitted a Billy Goat bash guard.
    Inner Melbourne. Can post at buyers expense.
    Contact:
    DM if interested
    482 Post(s)
    Nuffy Oldish Fart Query Ash Mate
    What is a “Billy Goat Bashguard” ?
    Dearly hoping it’s not a reversing whilst bogged steel sand/mud anchor
  3. The Following User Says Thank You to MB For This Useful Post:
    Cremulator (22nd October 2022)
    Jun 2018
    25 Post(s)
    Haha yep, it is.
    This is the photo of it from their website.
    But a wise man once said "big believer in stock designed positive/negative air pressure zones now.
    Many a great sand driver folks hate these ‘Air Dams’ as they ‘rip off’ when reversing have read but do believe down here they are integral for our highway needs."
    I fitted this to mine mostly for the air flow/air pressure while driving on the highway as mine didn't have the factory guard, like this, when I bought it
    (Source http://www.nissanpatrol.com.au/forum...l=1#post792459)
  5. The Following User Says Thank You to Cremulator For This Useful Post:
    MB (22nd October 2022)
    482 Post(s)
    Wise highway advice Brother Ash
    Please do go easy on damaging tracks too, it has been documented that aftermarket steel dams dented/bent hinder steering capabilities deep off-road careful
    May I ask if your Beautiful TD42Ti is possibly overheating?
    May have some hopefully helpful proven OEM tricks
    482 Post(s)
    FWIW: We ALL forget to consider our GQ & GU A/C Condenser’s out front and out bush and or highway hauling.
    TD42’s were poorly designed on the brink of Kettling out of the factory without Australian dirty/dusty fins.
    Imagine slapping a piece of half blocking ‘Coreflute’ in front of our radiators
    ……Holistic TD cooling needs view, wash/degrease lightly your Condenser’s too
    FWIW2: Just done this last week on my Ex’s TD42T and dropped it back by 10C to where I had it prior singing safely
    Cremulator (23rd October 2022)
  9. #6
    482 Post(s)
    FWIW3: Top tip, high volume, low pressure water is key to clearing fins without damage
    A standard garden hose reduced to a say 1/4” air line type fitting and say 20 minutes cleaning each side at least will drop 10C and no need to OEM replace unless the inner cores are knackered
  11. #7
    Jun 2018
    25 Post(s)
    It's been pretty stable temp wise.
    The peak temps I saw on our recent trip to Fraser island, fully loaded with two Expedition 134 boxes on the roof rack, were 95° and EGTs at 525°. Backing off/changing gear saw these drop pretty quickly.
    This was with the Billy Goat guard installed. I'm not sure if it has much effect, but I wanted to reinstate aftermarket pieces that aid cooling the same as factory items to avoid the potential of creating an engine that has overheating problems.
    I made this other guard to channel air flow through the radiator and prevent sticks going up through that gap.
  12. The Following 2 Users Say Thank You to Cremulator For This Useful Post:
    BrazilianY60 (23rd October 2022), MB (23rd October 2022)
  13. #8
    sunshinecoast
    hi cremulator . that is the first time i've seen the standard plastic air dam . that steel plate from the bullbar to thechassis might be a problem , on the zd30 with the wide shallow radiator it is good but on the td42 with the narrow deep radiator it seems to be a hinderance to cooling air flow . on the other patrol site there is a thread called AERO THINGS & HEAT MANAGEMENT ( COOLING SYSTEM ) . it is full of interesting info on td42 cooling issues .
    i just looked at that pic of the plastic air dam again . is that on a zd30 ? did td42s have the plastic air dam?
  14. The Following User Says Thank You to nipagu7 For This Useful Post:
  15. #9
    Patrol God Stropp's Avatar
    38 Post(s)
    I have a similar setup and on the beach at 10 psi tyre pressure in sift sand no temp problem, mind you I did fit the hi flow ufi fan and hub.1B8A73FC-DA67-4298-B061-EEDAECE5B221.jpeg
  16. The Following User Says Thank You to Stropp For This Useful Post:
  17. #10
    Jun 2018
    25 Post(s)
    Quote Originally Posted by nipagu7 View Post
    @MB took that photo of the plastic air dam, I'm not sure which vehicle it was fitted to.
    The plate from the bull bar to the chassis I made with the intention of replicating the factory plastic dam that was fitted to my aluminium bull bar.
