Ha.
Hahaha.
Haaaaaahahahahahahaahhahahaaaaaaaa.
Gutters.
Almost every single one of em, sooner or later. You have an advantage that it's black (captures heat, evaporates the water from the internal gutter)
If they aren't rusted through or repaired already I would pull the roof lining and flood it with your favourite rust treatment/inhibitor. Get frisky with a drill and make so water can drain out of it. They're 3 layers of steel bent stupidly together. I'll try and find a picture.
Lower rad support. Just because.
The lower shelf of the chrome bumpers, especially if it's been used to launch a boat/ on a beach/ anywhere they salt the roads for ice and snow - sand/salt piles up under em.
Wheel arches (same reason)
Sills/ body door rails, whatever you call em. Where the bottom of the doors close to. Also just because.
