Page 3 of 3 FirstFirst 123
Results 21 to 23 of 23
Thread: Need to build a half wall/ fence need some ideas…
    Patrol Freak Bidja's Avatar
    Jul 2017
    Southern Table Lands, NSW
    40 Post(s)
    @mudski, a couple of pics that might help give you some ideas. Check em out and can discuss if u want.
    Posts being cemented in the ground will depend what is down there, alternatively you could just secure the square hollow section (SHS) posts to top and bottom sleepers, using anchor threaded rod (Chemset) fix thru center of post into the top and bottom sleeper (be strong enough I recon).
  2. The Following User Says Thank You to Bidja For This Useful Post:
    mudski (17th October 2022)
  3. #22
    I assume this is for some fark tard office pen up his / her ass pen pusher council reg bullshit?
    Run Stainless Steel wire from a mount from you house bricks 2 where ever u need 2 end it
    OR
    Glass fencing
    What the width of the concrete sleeper?
    No council doesn't even know. We are putting BBQ there and it will need some weather protection. The sleeper are 75mm thick I think.
    NissanGQ4.2 (17th October 2022)
  5. #23
    So after some contemplation and talking with a mate of mine who makes steel fences and gates etc I have come up with this prototype bracket. It will be welded vertically to the H post, then a hole drilled into the top of the sleeper and a piece of thread rod chemset into the sleeper. Then bolted to either side of the bracket.
    Now to make four or them. My little 135amp mig is not up to this so I’ll prep the pieces up and my mate is going to weld them up for me.
    Cremulator (17th November 2022), mudnut (17th November 2022)
