Page 3 of 3 FirstFirst 123
Results 21 to 27 of 27
Thread: GQ TD42 vac pump Alternator recommendations?
    Apr 2015
    I credit alot of my research to this post by "cushjbc" on benzworld.org forum
    https://www.benzworld.org/threads/he...pumps.3041049/
    Vacuum Switch Schematic (1).pdf
    Im including how I wired mine expect I used thicker cabling for power and ground for the 30 and 87 wires
    If anyone does buy the PSF109S-81-330 Vacuum pressure switch
    note that it uses the smaller blade connectors, I bought these 4.8mm female blade connectors and crushed them with pliers a bit to fit the 4.7mm terminal
  2. #22
    Apr 2021
    Brazil
    Quote Originally Posted by Bozanceroz View Post
    the switch with the commodores is not what you want for the patrol
    its a 5v switch and operates between 0.4-4.8v
    Attachment 85933
    I see your point. This one is a sensor and the voltage corresponds to the reading and then a control unit takes decisions based on the reading.
    For this application we need just a vac switch, no need to report a reading.
    After reading this posts of yours, I started looking around here (Brazil) and found a bloke selling online new UP28 with the vac switch for "alternator vac pump replacement/conversion" on diesels. The price of the UP28 is actually very good. The price of the switch he sells is more then the UP28 itself. I am trying to find a vac switch that could be used for this at a lower price.
    This is how he is selling his stuff. Pretty "rough"...
    Here the UP28 is used on VWs like Jetta, Golf, Audi...
    Still donīt know from which application he is taking this switch.
  3. #23
    Apr 2015
    looks a bit similar to a volvo switch that ive seen on youtube, but is heaps different in design
    there is also a version of the UP28 which is a 3 pin instead of a 2 pin
    at the bottom of page 4 u can see the differences
    https://www.hella.com/resources-soe/...69076a_AM0.pdf
    that one looks like the one with the relay box
    im not sure if thats more suited for ECM controlled cars
  4. #24
    Apr 2021
    Brazil
    This one being sold here is definitely the 3 pin version. The third one is a signal that turns on the pump when grounded. So, the vac switch is only a NC switch that disconnects its two terminals apart once a certain vac level is achieved. See on his rudimentary arrangement that the ground that goes to the pump also goes to the switch and the thinner control wire for the pump goes to the other pin of the switch.
    This pump has a relay incorporated basically so other than a fuse, you would connect it straight to the battery, and the relay action is controlled by the third pin once earthed.
    Last edited by BrazilianY60; 14th September 2022 at 03:20 AM. Reason: I meant NC instead of NO
  5. #25
    Apr 2021
    Brazil
    The switch takes no power, it just opens two NC contacts. Possibly all mechanical with a diaphragm opposed to a spring (to provide for the level of vac required) pulling a rod that opens the NC contacts.
    Last edited by BrazilianY60; 14th September 2022 at 03:20 AM. Reason: Meant NC instead of NO
  6. #26
    Apr 2021
    Brazil
    Found it. It is from a GM applicaton.
    OEM:13251900
    Fitment : For Chevrolet Malibu Cruze Buick Regal LaCrosse
  7. #27
    Patrol Freak jff45's Avatar
    Morayfield, QLD
    A UP28 wouldn't run much at all in my intended application. The vacuum in my Patrol is now only needed for the diff lock and the idle up when AC is switched on.
    John
