Page 5 of 7 FirstFirst ... 34567 LastLast
Results 41 to 50 of 61
Thread: DIY Wheel Bearing Adjustment.
  1. #41
    177 Post(s)
    No, it will need a new axle seal. Will and Should ate 2 different words mate
    If the seal is gone and you ha e never done a rebuild then it really will make a difference. How many kms has your car done mate?
    140k.
    And apart from tightening the bearings as per this thread, nothing else had been touched or regreased, like , ever.
    177 Post(s)
    @Hodge yeah take out one of the lower king pin bearing bolts and see if anything drains out. If nothing your good to go.
    Drizabone both sides .
    I guess , most likely bit of water got through auto hubs ... So bead of silicone a trick as muddy suggested ?
  3. The Following User Says Thank You to Hodge For This Useful Post:
    MudRunnerTD (6th October 2019)
  4. #43
    Apr 2021
    Brazil
    Thank you @MudRunnerTD for the detailed explanation. Changed the tires on the GU today and took it for an alignment. The technician checked for all the bushings (all good) and for wheel play before setting up all the alignment gear, and actually found play on both sides. He ended up not setting up the gear and told me to adjust the bearings first and then go back for alignment. So here I am looking for knowledge from this great forum.
    I don't have the lock nut tool but it seems easy to make one. Meanwhile, I'll give it a shot trying to turn the locking nut using a pair of "bent nose" circlip pliers. Lets see how that goes.
    Cheers from Brazil!
  5. The Following User Says Thank You to BrazilianY60 For This Useful Post:
    MudRunnerTD (25th August 2022)
  6. #44
    178 Post(s)
    Cheers from Brazil!
    I made do with a home made tool for the first couple of years I had our GU. Buying a proper tool given how cheap they are & easier to use than the one I made had me wishing I'd just bought one in the first place. My home made one consisted of a length of steel bar with two pegs welded to it. Suggest you find an ebay seller willing to post to you from here (for future use) unless you can replicate the 'socket' type tool yourself. https://www.ebay.com.au/itm/193557575219
  7. The Following 2 Users Say Thank You to Cuppa For This Useful Post:
    BrazilianY60 (24th August 2022), MudRunnerTD (25th August 2022)
  8. #45
    Apr 2021
    Brazil
    Thanks Cuppa!
    I can definitely replicate it myself. Just wanting to tighten the bearings before Friday to get the alignment done and I won't probably have time to tackle the tool construction before that.
    Another way to build the tool that crossed my mind is looking for a pipe with the appropriate diameter, cutting two "less then a half-moon" out of it leaving the two teeth for lock ring engagement and welding a nut on the other end. Then instead of driving it with the square half inch ratchet alone, I would drive it with the ratchet plus corresponding socket to the nut.
  9. The Following User Says Thank You to BrazilianY60 For This Useful Post:
    mihit (26th August 2022)
  10. #46
    482 Post(s)
    In a rush as you are BZ Mate a baby sized cold chizel and lightweight self torque tapping hammer always works. I really should buy the tool one of these days too
  11. The Following User Says Thank You to MB For This Useful Post:
  12. #47
    482 Post(s)
    FWIW: (Bush Needs) Tap away lightly on your nuts when nearly home on the threads to compress dodgey washers, until your baby light hammer starts pinging/bouncing back.
    1/8 turn tap backwards (disclaimer) has always worked for me around perfect Nm
    The ‘ping’ feeling of steel/steel bounce back is no different a feeling of popping a tapered joint apart of steering links. Two equal weight hammers perfectly struck in time colliding with one joint magically works
  14. #48
    ^^^^^^^ What He Said ^^^^^^
    A punch and hammer will get it done.
  15. The Following 2 Users Say Thank You to MudRunnerTD For This Useful Post:
    MB (25th August 2022), mihit (26th August 2022)
  16. #49
    May 2022
    Tai Tokerau, RD8
    15 Post(s)
    I'd use a punch over a cold chisel, and you'll get a feel for how hard they need to be done up. (worst case you put the wheel back on and feel play you take it apart and do it again)
    I also drive forward, never back-off, to the next locking screw tab/slot/hole.
    Bearings can take a fuckton (metric) of preload before suffering damage, way more than you're going to put on it with hand tools.
    Your idea of hacking up pipe is a fine one. BTDT too. try and get a radius on the pegs so's it's not squarepeg roundhole.
    The actual locknut socket (41mm?) should be available from an engineering house, if you really feel the need for one.
    If you do have the socket then the procedure is to tighten it until the bearing siezes (hub can't turn) then loosen it off completely, then tighten to whatever torque is specified in the manual, 20 ish foot pounds, IIRC.
    1989 LWB 5-Seat, TD42
  17. The Following 3 Users Say Thank You to mihit For This Useful Post:
    BrazilianY60 (27th August 2022), MB (27th August 2022), MudRunnerTD (26th August 2022)
  18. #50
    482 Post(s)
    ^^^^^^What They Said
    Baby Cold Chisels/Punches with a slight say 10 degree woof/bend in them are even betterer in the bush and merely take up 0.00000001m3 of spares box space
