Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: engine swap on a gu series 4
    "adapter thingo" = Dakota Digital SGI-8E
    Thats him...
  2. The Following 2 Users Say Thank You to mudski For This Useful Post:
    jff45 (26th July 2022), MB (26th July 2022)
  3. #12
    483 Post(s)
    Quote Originally Posted by moparcm View Post
    it is a td42t
    Great News Brother, one less wire to worry about versus the TD42Ti injection pumps, I’m lead to believe from newer variant owners. Was it an immobiliser Ti 11mm pump extra thingy?
  4. #13
    May 2018
    You can use the ZD belhousing but you need to modify where the starter mounts.
    If you have the wide radiator, not the skinny tall one, you can use this just need TD hoses ,including heater hoses.
    The gearbox is fine to use.
    The crossmember you will need a TD one as this pushes the motor forward 10mm. Otherwise in reverse the exhaust manifold hits the firewall.
    Get Killa Kustoms to mod your loom, so much easier than trying to work it out your self.
    You'll need the weld on engine mount brackets to weld to the chassis. Patrol a Part sell these.
    TD accelerator pedal and cable.
    Clutch and flywheel of course, although I am told the ZD clutch fits. Just get the right one though and be done with it.
    Thats pretty much it from memory.
    can the zd crossmember be used? i cant seem locate a td one.
  5. #14
    You can but like I said, in reverse the exhaust manifold hits the firewall. And makes a horrible noise in the cab. Been there and done that.Theres only 10mm difference in the transmission mount spacing, not much.If you could fab up a adaptor plate to use on the ZD crossmember that would work.
    MB (30th July 2022)
  7. #15
    483 Post(s)
    Is there any overheating issues retaining the ZD original OEM radiator system versus installing an OEM TD42 radiator system?
  8. #16
    #LStheWorld just say'n
  9. The Following 2 Users Say Thank You to MudRunnerTD For This Useful Post:
    MB (1st August 2022), mihit (31st July 2022)
  10. #17
    483 Post(s)
    I’m unsure @MB reminder
