Results 1 to 7 of 7
Thread: GQY60 Left headlight, short to ground
Threaded View
  1. #2
    It can often be the plug, they are prone to melting and also a cause of voltage drop from high resistance meaning a dim headlight (even dimmer than the shitty normal output).
    Replacing the factory crap setup with an aftermarket loom and relays can often give a huge improvement in lighting and also fix any gremlins.
  2. The Following 3 Users Say Thank You to the evil twin For This Useful Post:
    MB (1st August 2022), mihit (2nd August 2022), MudRunnerTD (1st August 2022)
