Page 24 of 33 FirstFirst ... 2223242526 ... LastLast
Results 231 to 240 of 330
Thread: Garett's ford maverick 1990,
  1. #231
    176 Post(s)
    I got some headers bout 2.5 inch at the slave, when the pedal went I just shifted without the clutch until I got to town. although not much changing down the highway sitting on 90km/hr.
    sadly its not the first time I have changed gears in cars without clutches ...
    Different to mine. The slave cylinder jammed holding the clutch open. Could change gears, but no drive. RACQ chap was very puzzled but the mechanic knew straight off what the problem was.
  2. #232
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    grr see a trail of fluid running down the front left .... gotta investigate but I think I've blown a calliper ....
    top tip don't let your old car sit for a long time ...
    Now you tell me!!! *LMAO*
  3. #233
    Is be checking your blinker fluid also! Good to see your having fun getting back into it mate
  4. The Following User Says Thank You to rusty_nail For This Useful Post:
    mudski (22nd March 2022)
  5. #234
    476 Post(s)
    Yep same issue with mine. I bought a heat shield for the slave cylinder but it ended up vibrating apart so I wrapped the exhaust pipe in lagging. All issues gone…
  6. #235
    Patrol Freak garett's Avatar
    Jan 2015
    north
    21 Post(s)
    I had a look and yep the piston is squirting fluid when I push it back... rebuild kit looks like the go
    need to get me a hone,
    blinker fluid is fine mate, its the muffler bearing that's giving trouble.
  7. The Following User Says Thank You to garett For This Useful Post:
    mudski (23rd March 2022)
  8. #236
    Expert Brissieboy's Avatar
    Jul 2015
    Brisbane, Qld
    10 Post(s)
    Most truckies driving crash boxes will drive all day without using the clutch, using it only when needing to come to a dead stop.
  9. #237
    Jan 2015
    north
    21 Post(s)
    got my finger out and pulled the calliper down and cleaned it up. put new seals in it and bolted it back up.. it'll get bled later.
    looks like I have been volunteered to fix a couple trailers. brake issues and a wheel bearing.
  10. #238
    Jan 2015
    north
    21 Post(s)
    well now i am considering a turbo .... yeah i know rabbit hole. it will need a new/reco pump, injectors and a full exhaust,
    thinking i should have an intercooler and i guess i need to sort an air filter.
    it would be nice to get 4-500nm but i want it to stay reliable.
  11. #239
    Talk to @Rossco and @AB and @MudRunnerTD for some recommendations Garett.
  12. #240
    How much do you want to send??
    Borg Warner turbo
    UFI 250HP 12mm Pump
    Big airbox and Snorkel
    Front or Top mount Intercooler with 3inch in and out
    3 inch exhaust.
    New Clutch maybe?
    Decent tune
