Results 1 to 10 of 17
Thread: Lets talk Fridges (and new ideas)
    FNQGU's Avatar
    Jun 2013
    Cairns, Queensland
    21 Post(s)
    Does anyone else have a beef with the current options available for refrigeration?
    Drop slides suck right? Had one with a 40 litre National Luna fridge and I think the slide weighed in at over 40kg. They do solve the problem of being able to get into a fridge when it is in the back of a canopy or ute or mounted up high on top of a set of drawers or something but they are crazy heavy.
    Upright Fridges suck too right? Insulation is normally sh.it, everything falls over or out (or needs packing in containers so it doesn't), the cold air disappears every time you open the fridge door, and the freezer bit at the top is a waste of space.
    Drawer fridges that I've seen so far have also mostly been shite and I've refused to buy one. They are generally too small, not deep enough to fit the wife's bottle of wine, have poor quality insulation and wiring, and struggle to keep stuff cold.
    What if there was something that had proper A-grade fibreglass insulation, where the contents of the fridge didn't fall out when you open it? Something that didn't need a fridge slide or drop slide, and could be used as a fridge or as a legitimate freezer, with an upper shelf for smaller items and could still fit in the wine? And what if we could make it here in Aus and every component was serviceable and replaceable and not throw-away?
    Playing with ideas again at the moment...
  2. The Following 4 Users Say Thank You to FNQGU For This Useful Post:
    Cremulator (22nd May 2022), Hodge (22nd May 2022), Plasnart (22nd May 2022), Rossco (22nd May 2022)
    178 Post(s)
    Have you looked at vacuum insulation?
  4. The Following User Says Thank You to Cuppa For This Useful Post:
    FNQGU (22nd May 2022)
    Patrol God Stropp's Avatar
    38 Post(s)
    I have had a trailblazer fridge made by norcoast refrigeration in Qld for over 30yrs, it’s got 3” insulation but they are very bulky and won’t fit due to the drawers but it is 80ltr, I see they have a 65ltr work fridge now with a side opening door. Check the website for sizing and prices, I have been thinking of getting myself a drawer fridge to make it easier to get the cans out of, just a 20ltr as it will fit on my rear seat platform in the Side door.AF7B87DB-49FD-414D-B1FA-AD9A499755F1.jpeg
  6. The Following User Says Thank You to Stropp For This Useful Post:
  7. #4
    FNQGU's Avatar
    Jun 2013
    Cairns, Queensland
    21 Post(s)
    Fibreglass panel with refrigeration grade insulation in between at this stage mate. I might take a further look though.
    @Stropp - yes, very familiar with the Trailblazer, and they are excellent products. Same problem though. Hard to access. Imagine that front opening, but on an internal slide, so the whole guts of the fridge came out to you like a Fridge Drawer. An Upright Fridge Drawer, that was able to still retain a good amount of the cold air in it and you could then access the contents right in front of you.
  8. The Following User Says Thank You to FNQGU For This Useful Post:
    Stropp (22nd May 2022)
  9. #5
    FNQGU's Avatar
    Jun 2013
    Cairns, Queensland
    21 Post(s)
    @Stropp - like this? This will freeze to -18C as it has a proper compressor and is one we have been testing for a while now. Made it stubby height actually (:-)), but we have also fitted a computer type fan and frozen down the fish fillets too.
  10. The Following 5 Users Say Thank You to FNQGU For This Useful Post:
    Cremulator (23rd May 2022), Hodge (22nd May 2022), MB (23rd May 2022), mihit (27th May 2022), Stropp (23rd May 2022)
  11. #6
    483 Post(s)
    A wacky little idea Ben Mate, imagine a range of tallish slimline Podder type fridge/freezers. (Sawafuji Bulletproof Motors of Course)
    Instead of needing crazy weight mechanics to bring the entire F/F weight outside the truck, it could/should work the same bringing the contents/baskets out to swing drop down much much lighter.
    Best nuffy tonight myself description I guess would be a heavy home dishwasher power plant and lower the front door to have baskets/tubs/whatever pendulum swung down by 90 degrees to users level maybe
    Will find a pen and paper tomorrow somehow to sketch this may affect public knowledge for your patent though Brother
  12. The Following User Says Thank You to MB For This Useful Post:
    FNQGU (23rd May 2022)
  13. #7
    84 Post(s)
    I too have thought about what I want in a fridge.
    An upright, multi draw fridge with a door seal and latch for each draw. With or without a freezer draw as per customer request.
    Each draw is in its own separate compartment except for a grill or holes to spread the chill. Each draw is retained on a runner and drops down at an angle when drawn out to full length same as MB suggested. Each draw has a small whiteboard or similar for contents.
    Just send me 1% royalties when you market them.
  14. The Following 3 Users Say Thank You to mudnut For This Useful Post:
    FNQGU (23rd May 2022), jack (23rd May 2022), MB (22nd May 2022)
  15. #8
    38 Post(s)
    Yes mate that’s what I’d be looking at, how much approximately
  16. #9
    FNQGU's Avatar
    Jun 2013
    Cairns, Queensland
    21 Post(s)
    @mudnut and @MB - I get your thoughts.
    Will find some pics of some others that we've been testing too. Unless we can achieve some sort of economy of scale, it might be priced out of the market yet. Everything you see in the above has been hand made, welded, routed, glued etc. too.
    @Stropp - working on this still. In the meantime, have been testing the temperatures of the contents as well.
  17. The Following 4 Users Say Thank You to FNQGU For This Useful Post:
    Cremulator (23rd May 2022), MB (23rd May 2022), mudnut (23rd May 2022), Stropp (23rd May 2022)
  18. #10
    Don't just test one or two, you'll have to go through a fair few to make sure of even temps right across the drawer.
  19. The Following User Says Thank You to Winnie For This Useful Post:
