Results 1 to 5 of 5
Thread: TB42 Head Bolt Torque and Sequence Cheat Sheet
Threaded View
  1. #4
    Expert Arfa Brayne's Avatar
    Jul 2016
    Good to clean out the threads in the block with a thread tap if you've got one. Surprising how cruddy they get.
    Remember to make sure there is nothing (grease. oil, crud, gasket debris) in the bottom of the head bolt thread holes.
    Then lube up the head bolts and washers with a bit of gear oil before fitting.
    Re-torque (one at a time) after a few thousand k's when you adjust the tappets.
    "Can't" is a dirty 4 letter word.
    Best way to deal with a "Can't" is to chop off the "t" and brew it in boiled water for a few minutes.
    Sip on the "t", and consider what you've got left to work with
  2. The Following 2 Users Say Thank You to Arfa Brayne For This Useful Post:
    LandRoverGhost (7th May 2022), MB (7th May 2022)
