Results 1 to 4 of 4
Thread: change diff ratio for ls3
    Oct 2020
    Hi to all again poopsie here,has anyone got ideas on changing my current diff ratio which originally had 3litre crd engine to 3.5 to 1 in order to reduce revs on highway as ls3 conversion has plenty of power and does not need to rev at 2300rpm at 100 kms per hour on hyway or should i leave it at that.I understand that the auto 4.8 patrols had 3.5 to 1 ratios.thanks again.
  2. The Following User Says Thank You to poopsie For This Useful Post:
    MB (22nd April 2022)
    Manual or auto box? I installed the Marks 5th gearset into mine and it dropped revs by 250rpm at 100 in 5th
  4. The Following User Says Thank You to PeeBee For This Useful Post:
    482 Post(s)
    IIRC models owned, you’re currently running 3.9 : 1 GU factory 3.0L Wagon Poopsie Mate?
    PeeBee & Rossco here are super happy with their Marks 4wd 5th gear cog upgrades on their moderate/bigger diesels. If it were me I’d seriously investigate PeeBee’s lead further as 3.5 : 1 on steep bush tracks with an LS1 might run away a tad more than your needs unknown?
    Oct 2020
    Thanks for your replies,I will take into account of what you have said,things to consider.Cheers Poopsie.
  7. The Following User Says Thank You to poopsie For This Useful Post:
    MB (24th April 2022)
