Ooi do you mean hoop iron or something similar? Daz mentioned the same but it really can't move anywhere I want able to square the walls up, just built them level off the top retaining wall, then jammed the last frame in. I can't see it being able to shift left or right and the roof trusses hold the ins and outs. I mean at the end of the day, it's a shed, made from f14 grade timber, it's ridiculously overkill lol. Should be fine. I appreciate the mention though. The external cladding will hold the walls, but the internal walls will be fixed with 16mm ply also, once both sides are fixed on I don't think anything will move anywhere.
