GQ LWB Roller or GU LWB roller with 3.0L manual gearbox and transfer case
Keep in mind too Phil, the GU's run and ECU. Not sure how you'd go with converting the loom so everything works as it should. Particularly the tacho and temp sensor. Your going to need the TD accelerator pedal too as the ZD and TB is electronic.
