Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: fuel filter change
    Quote Originally Posted by pollenface View Post
    I always fill it up as much as I can.
    When you disconnect the hose between the pump and the filter keep it high with a zip tie as to not let any fuel drip out to minimize the chance of air bubbles.
    Pump it until it overflows then connect it all back together.
    I just use a fuel line clamp on each hose prior to undoing them. very minimal mess and easy to use.
  2. The Following 3 Users Say Thank You to mudski For This Useful Post:
    budgie (29th March 2022), MudRunnerTD (29th March 2022), pollenface (24th March 2022)
  3. #12
    Apr 2021
    Brazil
    stuffing a rag around the air gun is enough to push it to the filter, it is nice to have another person to help,
    you don't want to go over board with the pressure.
    That is an interesting trick, Garret. Thanks for sharing.
  4. #13
    Nov 2021
    Ive never really had much issue priming the filter,
    i spend more time trying to get the filter off then anything, doesnt matter how loose i do it maybe because its close to turbo and the heat running around there or the fuel lines running across
    the fire wall warm the fuel up i dont know. But i had to go out and buy an aggressive filter clamp to remove my fuel filter, normal filter removal tools are no match.
    There i nice little clamp off tool Mudski
  5. #14
    Quote Originally Posted by budgie View Post
    Move the housing to the RHS mate. Much betterer position.
  6. #15
    Nov 2021
    Do plan on it, but everyone things the rhs brackets are gold plated or something
