Page 522 of 570 FirstFirst ... 520521522523524 ... LastLast
Results 5,211 to 5,220 of 5693
  1. #5211
    482 Post(s)
    Preordered a week ago for local hard freeze supply collection at 9:00am tomorrow …….6 X 5kg Blocks & 12 X Cubed ICE (not that meth-phet sole destroying crud)
    Should keep tomorrow’s Fair Dinkum Shenanigan’s cold enough for EOY “We’re Still Alive” Top Team Celebrations
  2. The Following 3 Users Say Thank You to MB For This Useful Post:
    BrazilianY60 (22nd December 2021), Cremulator (22nd December 2021), Rossco (22nd December 2021)
  3. #5212
    Patrol Freak jff45's Avatar
    Morayfield, QLD
    Lokka? What made you decide on this type of locker?
    Sorry Mark, didn’t see your question before now..
    A Lokka suits the way I use the Patrol. I don’t do any hard stuff so this will just give me a cost effective way to add a bit of an advantage that might be helpful one day.
    It’s easy to fit myself in the shed. I’ve had the axles out before so no surprises there. I’ll just need to be careful with the diff centre weight.
    I couldn’t really justify the other options at twice the price, or more, for the amount of time I use the Patrol.
    John
  4. The Following 3 Users Say Thank You to jff45 For This Useful Post:
    MB (28th December 2021), mudski (28th December 2021), PeeBee (28th December 2021)
  5. #5213
    Fair enough mate. Will take some getting used to I would think having the lokka constantly engaged whilst in 4wd.
  7. #5214
    Morayfield, QLD
    I’ve read a fair bit about them and it just means you need to change some driving habits slightly. If you don’t take your corners under power, the teeth slip easier to allow the differential action.
    If it really gets annoying on long stretches where you can’t really get by with 2WD, you can simply unlock one hub.
    John
  8. The Following 2 Users Say Thank You to jff45 For This Useful Post:
  9. #5215
    Nov 2019
    Perth
    5 Post(s)
    A high lift jack base for mud/sand
    2008 CRD Auto Wagon
  10. The Following 2 Users Say Thank You to pollenface For This Useful Post:
    MB (28th December 2021), mudnut (28th December 2021)
  11. #5216
    482 Post(s)
    Hated by most PF Mate for genuine dangerous reasons but I still carry a couple of High Lifts for work and play on my steel tray utes and chunky steel trailers.
    Best can openers ever on wagon body/doors they can be and cheapo ones of old have nearly taken my face clean off skipping a cog
    Keep em super clean, CRC handy, and learn their mechanics/flaws prior to operation Brother
    Pumpkin/Exhaust jacks kindly educated to me here too a few years back for sand is my first go to these days on the GU wagon
  12. The Following 2 Users Say Thank You to MB For This Useful Post:
    jff45 (29th December 2021), mudski (30th December 2021)
  13. #5217
    Apr 2021
    Brazil
    Traded some used tires for such jack type some 10 years ago. Mine is a T-Max. It was a good deal since the tires would eventually get useless and the jack is still around, but I confess I have never had the guts to really use it. It is a cool tool but dangerous as it can be. And it must weight half my weight, that is another factor, LOL.
  14. The Following 2 Users Say Thank You to BrazilianY60 For This Useful Post:
    MB (29th December 2021), mudski (30th December 2021)
  15. #5218
    New 3kw renogy inverter arrived today to replace the previous unit I have that may have acid fume affected control boards from when a Calcium battery shit itself one weekend and filled the cabin with acrid vapour - ol' @MudRunnerTD can attest to the delightful pong and throat tickling coming up that TAF track when @MB ran out of fuel. Big bugger it is too.
  16. The Following 3 Users Say Thank You to PeeBee For This Useful Post:
    jay see (30th December 2021), MB (30th December 2021), MudRunnerTD (31st December 2021)
  17. #5219
    Needed anew mower for the block, and after hunting around decided on a Cub Cadet with 60" cut zero turn style, monster beast, handles 500mm grass easily at reasonable speed, cut the required 15m wide fire breaks on the 13ac block in 4 hrs, happy days.
  18. The Following 3 Users Say Thank You to PeeBee For This Useful Post:
  19. #5220
    Patrol God Stropp's Avatar
    38 Post(s)
    Kings 200w folding solar with mppt and extension cable to charge second battery on special $199 so it’s now sitting folded in half on my dash charging the battery while I have the fridge running to see how long before the battery runs down.
  20. The Following 3 Users Say Thank You to Stropp For This Useful Post:
    Avo (30th December 2021), jay see (30th December 2021), MB (30th December 2021)
