Page 3 of 3 FirstFirst 123
Results 21 to 22 of 22
Thread: ZD30 Lift Pump Mod
    Quote Originally Posted by 05Y61 View Post
    One more thing. I'm also installing a second filter should I put this filter first or after the factory filter?
    Depending on what micron the second filter is. The main filter will be around 8 micron, brand depending. So if your new filter has finer filtration ability, i.e 8 micron or less, it will need to be after the main filter, to catch what the main filter is unable too, if its like a 15 or 30 micron, before the main filter, to catch the larger particles to assist the main, finer, filter.
    BrazilianY60 (14th October 2021)
  3. #22
    Apr 2021
    Brazil
    Makes sense. Otherwise you would quickly clog the first (finer) filter and have a big restriction. Thanks for the explanation.
