ok .. so I had been down the path of sagging springs .. had new springs fitted with a (approximate) 2inch lift. Terrible wobbles. Had 2 degree castor correction which helped a lot.. had an offset bearing in the front left .. all sorted .. kinda .. went well for a while but then noticed pretty bad outer edge tyre wear on fronts. Wheel alignment all good (expected toe out issues but that was fine so they found that was fine), so suggested swap tyres front to back and inside to out. A whole lot better .. as in 98% .. suggested next step would be to fit an adjustable damper to get it spot on (mine was an an Ironman unit that I was talked into when springs were fitted). All other wear components are fine (according to my Nissan mechanic guru who has stopped me spending more money thus far). I still have the original Duelers on the car which may be so unevenly worn that they are causing the issue. I just cant be f"%&d anymore and want to get it all sorted so I can then get a set of 32 or 33's with steel rims on it and start from new. But don't want to do anything until the front end is sorted. Suggestions most welcome
