Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 48
Thread: TB48 Brake Booster Upgrade to GQ 2.8TD
  1. #31
    TB48 booster and master installed, bit of a squeeze, but fits. Tidy up of wiring on final leg I think.
    Bleed the brakes tomorrow and see it pulls up.
  2. The Following 2 Users Say Thank You to PeeBee For This Useful Post:
    Cremulator (28th June 2021), MB (28th June 2021)
  3. #32
    Almost done, just need to trouble shoot the diff locks, UHF radio and fuel computer as all dead - no doubt a simple wire on the wrong terminal. Also truck won't turn off via the turbo timer, intermittent fault as it was earlier in the day, no doubt a terminal issue again. Happy to hear the beast start up though after 4 weeks off the road. Going to start the gravity bleed of the brakes tomorrow so i can at least get it to the mechanic for him to bleed them properly and do a final look over the job.
  4. #33
    Doing a preliminary gravity bleed of the brakes tomorrow. Staring at pass rear, then drv rear, pass front and drv front, does the rear proportional valve need to be individually bled or will it clear via the two rear bleeds?
  5. #34
    Yes bleed it. Due to its operation and position it is best practice to bleed.
  6. The Following User Says Thank You to nissannewby For This Useful Post:
    PeeBee (4th July 2021)
  7. #35
    So that was an interesting exercise. I read and heard it should take 1 hr for the first wheel, 45 for the second then quicker for the final two. Well, 3.5hrs for pass rear, 1.5hrs for drv rear, 15 minutes for pass front and 5 minutes for drv front, nice and hard pedal. Still taking it down to the mechanic to have him re-bleed/check the job. I did get tripped up at first as the Willwoods have four bleed nipples per caliper, and I only saw the top outer nipple at first and cottoned onto the second top nipple after an hour. Anyway, bled both sides and all good.Brakes - rear.JPG
  8. The Following 3 Users Say Thank You to PeeBee For This Useful Post:
    Cremulator (5th July 2021), MB (4th July 2021), Rossco (4th July 2021)
  9. #36
    Nice one. . . Keen to see how they go tomorrow . .
  10. #37
    Thanks Rossco, as I suspected the bubbles cleared 10 mins after speaking with you, should have just persevered I guess, however they simply didn't seem to want to stop, then they did. Need to ring the mechanic to see when he has a first up morning slot this week.
  11. #38
    Trip down to mechanics for a brake bleed check, tiny bit out of pass rear, which did make a difference. Brakes are noticeably better, certainly have a better feel about them. Popped a photo in of 'exceptional flex' for some eye candy to all those chasing something like I have achieved - this was just before it started to teeterFlex.JPG on the edge of falling off the jack!
  12. The Following 4 Users Say Thank You to PeeBee For This Useful Post:
    Cremulator (9th July 2021), MB (9th July 2021), MudRunnerTD (9th July 2021), mudski (9th July 2021)
  13. #39
    She's look'n good, glad brakes are better you'd hope so
  14. #40
    Nice. Good to see its worked out for you.
