Results 1 to 6 of 6
Thread: Limp mode 3.0 Di
Threaded View
  1. #2
    Putting a hole in the EGR plate won't help with the Di engines. What I do know, when I had my Di, I was getting limp mode on anything about 16psi. I bought the HPD billet hi flow air flow meter housing. Also the hi flow lid they do. After fitting these I had my max boost set at 25psi and the cruise boost to 18psi and I never saw limp mode again. .
    The best thing I did to that motor. Hands down.
    If you want to drill a hole, 8mm is the hole size I used to do in the plates I sold when I had my shop.
  2. The Following 2 Users Say Thank You to mudski For This Useful Post:
    Avo (16th May 2021), Dr Gary (17th May 2021)
