Results 1 to 10 of 19
Thread: Small Part needed - can you help?
Threaded View
  1. #7
    178 Post(s)
    Worst case scenario Cuppa...
    Get rid of it, and hard-wire the corresponding wires together...
    Another option is, install a Wireless unit in the box with a remote. They're cheap as chips. And they all follow the same protocol. Usually 4 wires.
    Thanks Hodge. Getting to the wires would be a bit of a mission. The control box top is flush with the top of the bullbar, so I'm guessing it would mean having to pull off the bullbar, not easy witha bad back & no workshop. I did think about getting a wireless remote when we were back in Broome & discovered the original wired controller had gone bung, but at the time forked out the pot of gold necessary to get a new Warn replacement. Perhaps that was a mistake. With the wireless controllers does the transmitter remain plugged in to that connector on top of the control box permanently?
  2. The Following User Says Thank You to Cuppa For This Useful Post:
    Hodge (14th May 2021)
