Page 13 of 15 FirstFirst ... 1112131415 LastLast
Results 121 to 130 of 142
Thread: Rear Winches - Lowering Down versus Hauling Dead Vehicles Up
  1. #121
    WOW I think it's safe to say you MB'd the eff out of that one . . .
  2. The Following 2 Users Say Thank You to Rossco For This Useful Post:
    MB (5th April 2021), MudRunnerTD (5th April 2021)
  3. #122
    Hahahahahahah. GOLD. You did indeed MB the crappa outta that!!
    Nekminit #24vtheshitoutofthat
  4. The Following 2 Users Say Thank You to MudRunnerTD For This Useful Post:
    MB (5th April 2021), Rossco (5th April 2021)
  5. #123
    482 Post(s)
    24Volt rear electrical weaponary would unfortunately piff the #shitouta my little AggyBike catapult style Dazman
    https://youtu.be/u6FRvkIUsZA
  6. The Following 2 Users Say Thank You to MB For This Useful Post:
    MudRunnerTD (5th April 2021), Rossco (6th April 2021)
  7. #124
    482 Post(s)
    A wee bit more tweaking this afternoon, got rid of the bow shackle winch connection point as it was hindering/pinching the lowest possible reach:
    Seems to work well so far having repurposed recovery point 4.7T hitches as it now holds itself without any winch tension on the upper less important levelling arms:
    Platform test hoisted the little AgBike up including the shortened old Kanga loader MaxTwax ramps now securely supported/connected without the winch breaking a sweat:
    Removable tail light/number plate plastic trailer beam rail brackets in place and finally a 5th recovery hitch (not for hauling) only as a backup high lift jack point in case the winch ever claps out:
    Tie down/up points for the Aggy and entire rack system are next on the agenda before it’s first upcoming test adventure
  8. The Following 5 Users Say Thank You to MB For This Useful Post:
    Cremulator (7th April 2021), MudRunnerTD (6th April 2021), PeeBee (6th April 2021), Plasnart (6th April 2021), Rossco (6th April 2021)
  9. #125
    482 Post(s)
    Forgot to photograph but removed the temporary plastic pipe modified bushes used to test the mechanism originally as can be seen on the main connection ends getting painted below:
    The boys at work kindly popped into Bearing Wholesalers-Lilydale on their way home for me and picked up 2 x brass (24mmOD x 16mmID x 30mm Long) bushes that has now made the whole contraption with 16mm HT bolts extremely tight and has kept the platform finally level throughout second tests
  10. The Following 4 Users Say Thank You to MB For This Useful Post:
    AB (7th April 2021), PeeBee (6th April 2021), Plasnart (6th April 2021), rusty_nail (6th April 2021)
  11. #126
    Once again.
    Your an ideas man MB
  12. The Following 2 Users Say Thank You to jay see For This Useful Post:
    MB (6th April 2021), Plasnart (6th April 2021)
  13. #127
    Once again.
  14. The Following 3 Users Say Thank You to Plasnart For This Useful Post:
    jay see (7th April 2021), MB (6th April 2021), mudnut (8th April 2021)
  15. #128
    482 Post(s)
    Truly do miss being first at the news agency to weekly grab the good old Trading Post and a highlighter Plassy Mate
  16. The Following 3 Users Say Thank You to MB For This Useful Post:
    MudRunnerTD (7th April 2021), Plasnart (6th April 2021), Rossco (7th April 2021)
  17. #129
    Do Not under Any circumstances join Facebook!! Thr Marketplace will do your head in. Lol. And you'd be racing me....
  18. The Following 2 Users Say Thank You to MudRunnerTD For This Useful Post:
    MB (7th April 2021), rusty_nail (8th April 2021)
  19. #130
    482 Post(s)
    AggyBike is on and ready for an adventure finally
    Just need some fork chocks and better tie down angles and we’re off to pull some mono’s.....in the GQ up some rocky hills
  20. The Following 9 Users Say Thank You to MB For This Useful Post:
    Cremulator (9th April 2021), jay see (8th April 2021), mudnut (8th April 2021), MudRunnerTD (8th April 2021), NissanGQ4.2 (10th April 2021), Plasnart (8th April 2021), Rossco (8th April 2021), rusty_nail (8th April 2021), Touses (9th April 2021)
