Page 1504 of 1670 FirstFirst ... 15021503150415051506 ... LastLast
Results 15,031 to 15,040 of 16693
  1. #15031
    84 Post(s)
    Our fridge is more like a menagerie than ever before. Its full of chocolate spiders, hedgehogs, a turkey, a chicken, half a pig and a hunka beef.
  2. The Following 2 Users Say Thank You to mudnut For This Useful Post:
    MB (24th December 2020), mudski (24th December 2020)
  3. #15032
    177 Post(s)
    Did you track down the out of alignment culprit @MB? Talk to @mudski about green Fleetline 8 rib belts, tuff as and dimensionally stable also. I have shredded a few of the straight black normal duty beilts on mine as you know, but not a fleetline.
    Can highly recommend.
    Got some through Mudski. Just holding it in your hands you can feel the difference compares to genuine ones ( that I've been using ) ...
    Very good bit kit.
  4. The Following 4 Users Say Thank You to Hodge For This Useful Post:
    MB (24th December 2020), MudRunnerTD (16th January 2021), mudski (24th December 2020), PeeBee (24th December 2020)
  5. #15033
    Success, bonnet issue resolved. The pressed channel that runs from guard to guard and holds up a host of things, was deformed where the catch sat. I ended up cutting down a metal 'square' I had and then pulled out the protractor and compared the angle of the front pressing in other spots and it was out about 2 deg!!!! So I packed up the bottom of the new catch and the bonnet closes with a light push instead of the 200mm drop as before. I am guessing the extra scoop weight as @MB mentioned has pushed the bracket downwards - happy days
    Also hooked into the passenger side BOSS rear spring support - still took me 2 hrs, and my spring seat must have some minor distortion as the new unit would not seat without taking a sander to a couple of bits to linish the edges off. One hell of a lot easier to install than the drivers side. I did destroy a set of heavy spring compressors, so borrowed the neighbors and destroyed them as well - those Dobinson 300kg coils are a bastard to compress.
    So, under bonnet temps with a 10mm packer at the rear of the bonnet, removed the rubber seal and 2 x 100cfm bilge fans flowing over the exhaust manifolds - what was 90 deg+, now 67 degC, happy with that result. Fans run all the time the engine is running.
    Next is the 5th overdrive gears on Jan 12, then sometime later this next year the Willwood Brake upgrade.
  6. The Following 4 Users Say Thank You to PeeBee For This Useful Post:
    MB (24th December 2020), NissanGQ4.2 (25th December 2020), Winnie (24th December 2020), Yeti's Beast (26th December 2020)
  7. #15034
    WA Wheatbelt
    23 Post(s)
    One more sleep then those damn, annoying lights should come down.
    Hip, Hip, Horray. No pun intended MR. lol
  8. The Following User Says Thank You to DX grunt For This Useful Post:
    MB (25th December 2020)
  9. #15035
    Oh shut up you! yes I had 2 pay, but in the long run will pay for itself over and over and over again so well worth it.
    How did you manage 2 get a free log splitter???
    He's a wood slut
  10. The Following User Says Thank You to Avo For This Useful Post:
  11. #15036
    Some 100 proof after a long day of work, yes I worked today. Nom nom.
  12. The Following 4 Users Say Thank You to mudski For This Useful Post:
    Avo (26th December 2020), MB (25th December 2020), TPC (29th December 2020), Yeti's Beast (26th December 2020)
  13. #15037
    177 Post(s)
    First day of "some" time off ...
  14. The Following 6 Users Say Thank You to Hodge For This Useful Post:
    jack (26th December 2020), jay see (26th December 2020), MB (26th December 2020), mudnut (26th December 2020), mudski (27th December 2020), rusty_nail (26th December 2020)
  15. #15038
    482 Post(s)
    If anyone out there deserves some time truly off it’s you Hodgey, Merry Christmas & hope you have a bettterer 2021 Mate!
    Thanks also on behalf of us Mexicans for keeping the power lines running for all our cold beer & prawns yesterday Legend ⚡️
  16. The Following 5 Users Say Thank You to MB For This Useful Post:
    Hodge (27th December 2020), jay see (26th December 2020), mudski (27th December 2020), Rossco (27th December 2020), rusty_nail (26th December 2020)
  17. #15039
    84 Post(s)
    mudnutette gave me some modelling clay for Christmas. End Result: A new avatar pic.
  18. The Following 6 Users Say Thank You to mudnut For This Useful Post:
    10G (27th December 2020), Avo (26th December 2020), jay see (26th December 2020), MB (26th December 2020), Plasnart (26th December 2020), rusty_nail (26th December 2020)
  19. #15040
    Not only for today, but happy for a few more weeks I reckon..
  20. The Following 2 Users Say Thank You to jay see For This Useful Post:
    MB (27th December 2020), mudnut (26th December 2020)
