Results 1 to 9 of 9
Thread: Td42 billet crank
Threaded View
  1. #8
    Patrol Guru 0-TJ-0's Avatar
    Jan 2017
    South Australia
    11 Post(s)
    If you replace the crank and bearings, won't the rings smash into the step at the end of their wear pattern?
    I don't know what "should" be done but I had an old Landcruiser that had all the bottom end bearings done leaving the rest of the engine alone. Got it off the guy I used to work for like that, never had any issues.
    I think perhaps tolerances would be tighter on new materials would actually end up making the rings stop slightly shorter than with "worn" parts.
    Dunno. Not a mechanic haha.
  2. The Following User Says Thank You to 0-TJ-0 For This Useful Post:
    mudnut (5th November 2020)
