There are supposed to be some good ones but the couple I was given to try were both rubbish. Look good but the lighting pattern was terrible. They threw the light around like one of those mirror balls in a Disco so you had these bright and dark patches off to the sides and poor overall intensity down the centre
Also, for anyone contemplating HID's the best insert by far in a 7 Inch insert headlamp is the "standard" style with the diffuser in the lens as it maintains reasonably close to original cutoff and spread patterns
Only drawback is possible water ingress once you go from Sealed to Semi sealed beams but that is true of any Insert
