Results 1 to 10 of 30
Thread: GU TD42 Dash temp Gauge problem
Threaded View
  1. #16
    @mudrunner My having put the coolant sender where most with TD42's do - screwed in just above the the water pump, may show cooler temps as a result? (Where is the factory sender located?).
    I run with 80 to 90 degrees showing depending upon ambient temps. Only above 90 on long slog hills. I recently looked to see what Redarc gauges cost & was shocked. Did I really spend that much on them? But I am so used to driving with them now I'd hate to be without them . Oil Pressure/ Coolant temp on one, & EGT & boost on the other. Love'em.
    The tip of that probe mate will barely be inside the s/tat housing, if at all. I have the same probe and they are quite short.
    Tip12345 (8th September 2020)
